V6 Driveshaft
Old 01-01-2008, 10:39 AM
Moderator
JimC's Avatar
Default RE: V6 Driveshaft
ORIGINAL: LX200
ORIGINAL: JimC
Yes, there is a "fix" - I have the Shaftmasters aluminum driveshaft. Lighter, stronger, and the car accelerates much faster. After 2005 Ford changed the clips on the stock driveshaft, but it still has some limits and I found that my 2006had a vibration that would not go away. I put the Shaftmasters onand no vibration, just smooth acceleration and smooth ride.
Definitely was worth the upgrade. Shaftmasters is a site sponsor and their website is www.shaftmasters.com
Jim... you could actually feel a performance benefit from this??? How hard was the install?
The difference is amazing - the car accelerates faster and runs smooth. I took it to the track the next weekend and the only change was the new driveshaft and set a new personal best so it confirmed for me that the car was quicker. It was so differentthat I was surprised to see that I was cruising at 85mph and didn't realize it.
I had it installed at a shop and it was so fast that I thought they must have found something wrong when they took the car off the lift - 15 minutes was all it took them. If your car is lowered and you have the Shaftmasters 4" shaft it takes a little longer because the emergency brake bracket has to be relocated. But if you are lowered and go with the new Shaftmasters 3.5" shaft then it is a quick drop the old and put the new one in replacement.
JimC is online now
Old 01-02-2008, 01:24 PM
billybix76
billybix76's Avatar
+1 !!
I have the 3.5 and its all Jim says it is.
billybix76 is offline
Old 01-02-2008, 01:54 PM
Sancho805
Sancho805's Avatar
ORIGINAL: billybix76
+1 !!
damnit you guys!!!......now i want one!! [8D]
Sancho805 is offline
Old 01-02-2008, 02:26 PM
raylandm
raylandm's Avatar
You guys are making me think of stuff to put on my car that I didnt know existed!! Youre all killing my wallet!!!
raylandm is offline
Old 01-02-2008, 02:40 PM
oh6vee6
oh6vee6's Avatar
Lower rotational mass FTW!!!
oh6vee6 is offline
Old 01-02-2008, 02:57 PM
retropony06
retropony06's Avatar
3.5 or 4" what is the benefit of the larger DS
retropony06 is offline
Old 01-02-2008, 03:42 PM
Sancho805
Sancho805's Avatar
ORIGINAL: retropony06
maybe strength?
Old 01-02-2008, 04:56 PM
pascal
S197 Section Modder-ator
pascal's Avatar
This car belong to a member of the Legeng Lime Registry, witch I also belong to.
There was a thread on that site a while back about the weakness of the sixer DS.
Theowner found out that analuminum or betteris a must haveabove 100mph and for any4.0 with force induced at any speed.
Mine will come off as soon as my Vortech is in sight[8D].
pascal is offline
Old 01-02-2008, 08:40 PM
Moderator
JimC's Avatar
ORIGINAL: Sancho805
maybe strength?
As I understand it the benefit is if you are lowered the 3.5 doesn't require any other modification to your car because it will clear everything. I don't know if the 3.5 weighs significantly less, but I don't think that there is a strength difference either. Shaftmasters can tell you on the weight difference probably.
JimC is online now
Old 01-04-2008, 04:20 PM
billybix76
billybix76's Avatar
There is a difference in wall thickness between the 4 and 3.5. The 3.5 is thicker and according to Shaftmasters is stronger because of it. 3.5 is rated to something like 5000 lbs of shear force and rated to 600HP. The size diff is also a cost diff. the 4 inch is $380 and 3.5 is $500+. The weight of the 3.5 is almost exactly the same as the 4 inch.
If you are N/A or even mild F/I the 4 is good unless lowered, or your name is Rygen or Buckman, then 3.5 is a for sure.
mtgldr
02-03-2024 09:00 PM
baddog671
07-26-2016 01:20 PM
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
Matt's 95 Stang
10-05-2015 07:16 AM
FivePointToTheOh
09-14-2015 03:35 PM
Quick Reply: V6 Driveshaft
