FRPP Exhaust, Headers.
Old Mar 14, 2008 | 01:52 PM
MustangMatt87's Avatar
MustangMatt87
Default FRPP Exhaust, Headers.
Hello everyone,
I have a few questions.. I got a brand new 08' mustang v6. and i was wondering what would be the best thing i could do first as in parts wise.. I was think of get a Cold air intake and than headers and then the FRPP exhaust. Would that be a good decision?? And is the FR exhaust good? Ive heard a few videos of thm but its hard to decide because of the quality of the video.. has anyone heared them in person and if so how are they? Can i get some advice on decent cold air intakes and headers... thank you
Old Mar 14, 2008 | 02:50 PM
ODDYSEY's Avatar
ODDYSEY
Site Moderator of Fury!
Default RE: FRPP Exhaust, Headers.
FRPP exhaust is awesome, the videos do it no justice at all. Headers are an expensive mod for minimal gain unless you plan on going F/I in the immediate future I wuold recommend other mods first.
Old Mar 14, 2008 | 03:58 PM
addison85's Avatar
addison85
CAI + tune. Mustang 101. I recommend C&L for the CAI and Bamachips 93 Race tune.
Old Mar 14, 2008 | 10:34 PM
my first mustang's Avatar
my first mustang
A CAI and tune are the first things to do. Any decent CAI will not work without a tune(reflash),it will set off the "check engine" light. Vmp,Bama,Brenspeed and a few others are the ones to look at. Most have a power package(cai & tuner)for a good price. FRPP dual exhaust is also a good choice too,but the Cai and tune should come FIRST. You will like what the tune will do to your Mustang V6 especially if you have an automatic. Save the headers for later.
Old Mar 15, 2008 | 05:52 PM
MustangMatt87
hey oddysey.. u said sumthin about a "bamachips99 race tune" whats that... i am new to this and i have no clue.. also ur thing says FRPP GTA's exhaust... if i get the FR exhaust from ford racing.com, i think its $600 ish.. do they come with the GTA's or are they different.. thank you.. and what other mods can i get before i get the headers.. any suggestions from anyone out there??
Old Mar 16, 2008 | 01:48 PM
themac5150's Avatar
themac5150
ORIGINAL: MustangMatt87
Hey Matt, welcome to the forum, bamachips is the website, they sell cold air intakes and tuners(hand held gadgets you plug into the recepticle under the drivers side dash). Doug Studdard makestunes, if youread bama or Doug, they are usually the same. The 93 race tune, is a tune for 93 octane premium fuel. When you order a cold air intake/tuner package form bama and most others, you get a choice of 3 tunes (thats all theXcal2 will hold). I have an 87 (regular gas) performance tune, a 93 (premium) torque tune (makes more torque lower in the RPMs, great for day to day driving, leaving stop lights, etc.) and a 93 (premium) performance tune (more power in the upper RPM range).
Because the new cars are fly-by-wire on the gas pedal (there is no physical cable that performs the opening and closing) the computer does it. These tunes adjust your ignition timing, throttle response curve(opening/closing), and on autos, shift points and pressures.On intakes that increase the MAF housing(bigger hole, lets more air pass) like the C&L,the tunes also tell the car to increase the fuel to keep the car from running too lean (not good). I havebama tunes, in anSCT Xcal 2 programmer, with a C&L intake that I bought from bamachips. There are many out there that have different brands from different tuners, that accomplish the same thing, the choice is up to you. But, If you do buy an intake that requires a tune, you HAVE to purchase tunes and a tuner to use it, or you risk damaging your engine. That damage will not be covered byyour warranty.
On 87 tunes, it basically smooths up the engine response, and throttle, and if you have it, takes advantage of the extra air the bigger MAF housing is sucking in. On the higher octane tunes,they use ignition timing changes to take advantageof higher octane fuel's ability to retard detonation (pinging). You can use93 octane fuelwith the87 tune if you have to, but you can'tuse 87 octane fuel with the 93 octane tune, the car wouldping andknock, and possible engine damage could result. Are youfollowing?
The Ford Racing dual exhaust kit for the V6, comes with GTA mufflers. These are a different part number performance muffler. The GT has a couple of choices, the GTAs (last digits of the part number are 50 state legal for sound, the 5GTs (last of the part number again) are only 49 state legal for sound. With the FRPP (Ford Racing Performance Parts) V6 kit, you get the 50 state sound legal mufflers, the extra hangers, the X pipe, new mid pipes to connect the X pipe to the mufflers, and clamps to seal the X pipe to the catalytic converter side and the mid pipe side (a shop could weld them if you wanted to pay for that), and insert that pretty up the holes you have to cut in your bumper cover to install the kit. Its not that hard, and if you're good with a wrench, only takes a few hours to do.
I have the FRPP duals kit, and JBA shorty headers (shorty headers keep your factory emissions devices installed) and are legal. I chose to do them at the same time as the duals because I was under there and had the entire exhaust system out anyway. They are the silver ceramic colored, and are much prettier to look at than the stock rusty manifolds. Whether they actually make a difference or not, I don't know. The car sounds much better, no video gives an accurate sound of the car with the duals installed. I had planned on eventually installing the high performance x-charger, the duals will help maximize the potential for a supercharger. With gas prices soaring, and not looking any better any time soon, I may not go that route. With a supercharger installed, you're stuck buying 91 octane or better fuel from that point on. I enjoy being able to put in the 87 octane when ever I choose to. To get back to 93, that requires running all of the 87 out of the tank, filling up with 93, and run almost atank of that, refilling again with 93before installing my 93 tune (the torque tune being my favorite). And you have to remember what tune you're running when you stop and fill up. Yes, I have forgotten, and had to retune to 87, that's why the tuner stays in the car. I even remembered that I had the premium tune installed, but didn't realize the gas station's premium wasn't 93 octane, it was 92! I was half way through the fill up before I notice the yellow sticker. Took a minute or two to reflash to my 87 performance tune then off I went. The car felt like a different car after the intake and retune from bama. It really seemed to uncork whatever potential was hiding in there. You can really tell the difference if you run the tunes for a while, then pop in the stock air box and tune, for giggles.
Old Mar 16, 2008 | 09:08 PM
Bulliitt68's Avatar
Bulliitt68
Great post themac5150. Does using the 93 tune give you better gas milage?
Old Mar 16, 2008 | 09:34 PM
themac5150's Avatar
themac5150
ORIGINAL: Bulliitt68
I usually use the 87 performance tune on trips, it's cheaper, and you never know what grade the station is going to have on the road. I was getting 29 to 30 mpg on the interstate going 70 mph. I have a manual, I put on the cruise and never have to down shift. Sometimes if I would be between 70-75mph. That was with the C&L, bama 87 perf tune, and the FRPP/Borla axle back. I haven't made any long distance trips with the dual/headers on yet, so I don't know if that hurt or helped. Around town, with the 93 torq tune, the milage is worse, because it's so fun to get to 45mph as fast as I can!
Oh yeah, on trips, I'm not the guy passing everyone in the sports car, I'm the guy everyone is passing, cursing as they go by, because I have the audacity to go the speed limit(or dang close to it)! If I could survive on the road going 60, I would. They milage would be even better.
Old Mar 16, 2008 | 09:35 PM
ODDYSEY's Avatar
ODDYSEY
LOL themac answered it all perfectly.
I have the 93 race tune from bama.
FRPP kit comes with dual GTA's
other mods? CAI/Tune, springs, rims/tires, dual exhaust, some appearance mods.
Old Mar 19, 2008 | 01:50 PM
MustangMatt87
Thanks, themac.. u helped me out ALOT.
I have a few other questions for anyone to answer..
The FRPP Exhaust.. it won't sound ricey will it???
I'll prolly just get a cold air intake with a tuner. and exhaust so i'm HOPING that it'll sound good.
Here is my question, i was on the Bamachips website.. and i found the (05-08 Mustang V6 C&L Intake and X Calibrator 3 Combo for $625.00,) Do i need to buy a tuner thing or what im confused with that or is the x calibrator 3 the tuner.. and if i need to get a tuner does the place i buy it from tune it for me before they ship it or what? Because im thinkin of get the 87 octane but also be able to put 93 in also.. I guess that right.. What do most people perfer the 87 or 93? Thanks
