Axle Back
Old Apr 15, 2005 | 02:32 PM
  #21
BradC's Avatar
BradC
Default RE: Axle Back
Are you talking about needing these hangers to hang the other GT muffler, or the replacement for the stock V6 one? I guess my real question is, if I get a GT takeoff muffler to replace my V6 one, do I need a hanger or will it fit directly where my current one is?
Old Apr 15, 2005 | 04:59 PM
  #22
cheysdaddy's Avatar
cheysdaddy
"Any company that claims that true duals will result in a loss of power needs to back it up with hard evidence, like a dyno sheet. "
What I have personally heard about power loss with true duals is that you might lose alittle low end torque but it didn't sound like very much (maybe 5-10ft/lbs) Personally I'm getting an entire GT exhaust system and making a cat-back system out of it. Couldn't pass it up only $200 for the entire system from the headers back to the muffler. I'll let everyone know how it goes in a couple of weeks after I put it on. I'm also gonna just have my valance cut to match. You really won't notice a difference unless it's in the air.
Old Apr 15, 2005 | 05:15 PM
  #23
toronado's Avatar
toronado
ORIGINAL: BradC
you only need to concern yourself with hangers if you're going to install the second muffler. when you replace the v6 muffler with the gt muffler you'll use the same hangers and there is a third, different hanger you will remove and won't need. Keep the bolts though in case you decide to hang one on the driver's side.
i'm walking out the door now to install my new hangers.
Old Apr 15, 2005 | 05:21 PM
  #24
toronado's Avatar
toronado
ORIGINAL: cheysdaddy
$200 sounds like a good deal. Looking forward to hearing from you on the results.
Old Apr 15, 2005 | 08:59 PM
  #25
Lizardking's Avatar
Lizardking
$200 for an entire GT system, Im envious.
I crawled under for a look today. The GT mufflers have 2 connection points. The one near the outlet looks like a direct fit. The other one that is near the inlet is 90 degrees out from the bracket that is on the car. So it looks like the only way to hang the GT muffler is by the clamp and one connection point near the outlet. Im going to the Ford lot and looking for a GT to see how those are hung.
Im also thinking about cutting the rear bumper for the other muffler, looks like an easy task for a body man.
Old Apr 16, 2005 | 12:13 AM
  #26
toronado's Avatar
toronado
ORIGINAL: Lizardking
the gt muffler slides right into the two hangers exactly as the v6 muffler does. the only difference is you won't be using the extra third hanger you removed when you uninstalled the v6 muffler.
i attempted to install muffler hangers for my driver-side GT muffler today and failed miserably! [:@] Sadly, I couldn't get any bolts in - it seemed impossible. So I'll be paying a muffler shop to hang it I suppose.
the last part of today's story that I cut the opening for my other tailpipe today with a box cutter! I made an outstanding stencil with the back of a spiral notebook, I measured and cut the opening in the correct location, and it turned out "ok". The part you cut is very thin so a good blade goes right through it but it was pretty nerve-wracking and I did accidentally make a couple of minor blade scratches and it could stand to have the edgs smoothed up a bit but overall I'm pleased and glad I did it myself. Only someone doing some intense visual scrutinizing would notice its imperfection.
so i'm going to see about completing my dual setup tomorrow morning. hopefully I'll have some good news to post.
Old Apr 16, 2005 | 02:12 AM
  #27
Lizardking's Avatar
Lizardking
toronado, Something is amiss on my car. If I lay my V6 and V8 mufflers side by side the mounting brackets are different.
Standing behind the car my V8 muffler has both hangers pointing toward the 6 o' clock position.
My V6 muffler has the rear hanger pointing toward the 6 o' clock position, but the hanger near the inlet points toward the 3 o' clock position.
Is that how yours looks? I havent looked closly at the hanger to see what kind of problem this is going to make. My two hangers on the car are different, are yours?
I take it the hanger you say you arent useing is the bracket that is welded on the V6 muffler with the 2 bolts securing it to the frame.
Any chance you can e-mail me a couple up close pics?
Old Apr 16, 2005 | 03:09 AM
  #28
toronado's Avatar
toronado
sorry no pics but when you remove the v6 muffler you should remove the "3 o'clock" hanger bracket too. only the two "6 o'clock" hangers will be used for the GT muffler.
Old Apr 16, 2005 | 10:40 AM
  #29
Lizardking's Avatar
Lizardking
Do I feel stupid. Every time I crawled under the car, I was on the inboard side. This morning I crawled under the outboard side. Behold! There is the missing hanger I couldnt find. Its all clear now.
How tough was it to cut the bumper cover? Takes alot of guts to start sawing on a new car.
Im still feeling pissy about the $38 hangers. I feel like Ford pulls a gun on me every time I walk in there.
If I cant find some in the j-yard, Im going to pull one off and get a buddy in the metal shop to fab me some up.
Old Apr 16, 2005 | 01:45 PM
  #30
BradC's Avatar
BradC
If you have a Dremel (rotary cutting tool) I would try using that instead of a box cutter. If the valance is as thin as you say, you'll make short work of it with a Dremel and it will give you nice, clean edges.
