short tube headers
short tube headers
are the short tube header kits for the 05-08's V-6's worth the horsepower increase for the money. i have heard that the short tubes only add about 10 hp. is this true. also which company makes the best set.
2006 4.0
mmr intake
demon coil w/ 9mm power cables
magnaflow axleback
bbk 70mm throttle body
2006 4.0
mmr intake
magnaflow axleback
RE: short tube headers
if 10hp is true plus the improved sound you get anyways, then the stainless steel shorties are worth it to me. ceramics are too pricey and unecessary for our cars IMO. 5-7hp has generally been the agreed upon amount of gain.
not really sure on the best set but JBA shorties are high quality and fit nicely.
i dont have headers...yet, but i've read some writeups by members who have installed them. its definitely doable if you are handy with basic hand tools and have patience. if the search is working now, look it up. i forgot the members name that did a whole write up on the install.
http://www.mustangmonthly.com/techar...ers/index.html
I didn't look in here so I don't know if this is for V6's or V8's but I think the process should be the same.
I was under the impression that headers give NO HP increase and if they do it would be Long Tube headers with some kind of F/I only then will you get a small amount of HP increase. Am I Wrong about this?
I may be wrong, so somebody please chime in if I am, but I think a small amount of HP is gained with the absence of the cats and mufflers. So basically, all you're looking at is a straight through system with long tubes.
i got jbas i picked up about 10 and they sound way better then manifolds do. the jbas are top notch. next looks at pypes shorties i put some on my gf car. they are sweet to very comparible if not better the jbas witheither one you cant go wrong.
ORIGINAL: 1badV6
i got jbas i picked up about 10 and they sound way better then manifolds do . the jbas are top notch. next looks at pypes shorties i put some on my gf car . they are sweet to very comparible if not better the jbas with either one you cant go wrong.
