V6 Dual Exhaust Upgrade
Old Jun 15, 2009 | 05:36 PM
Topless Stang's Avatar
Topless Stang
Default V6 Dual Exhaust Upgrade
Man...I was all set to buy the BOOM Tube dual exhaust kit...until I read that it's not really a true dual set up. It still forces exhaust gas into a single tube before breaking out to the two outlets. I don't think I'm left with many options after that. I can either piece it together myself(mid pipes, tubing, etc) or buy a true dual conversion muffler delete kit from Pypes. The funny thing is the price of the true dual conversion kit from Pypes is the same with or without mufflers...$300. It just chaps my *** spending the same amount for a kit without mufflers. Does anyone have any other suggestions for converting to a 'true' dual setup and still being able to use the BoomTube axlebacks? Thanks!
Old Jun 15, 2009 | 05:44 PM
3.73-11's Avatar
3.73-11
hey man all you need is a x/h pipe and a set of over axle pipes like a set of someones stock gt takeoffs&your good to go using your boomtubes shouldn't cost much over $250 if you don't want to do that just order the kit with muffler and re-sell them to make a little on the back end
Old Jun 15, 2009 | 06:47 PM
Topless Stang
After looking around I think I have the best solution...feel free to chime in with any other options you think I may have. Thanks!
Boom Tube Conversion Kit for $399
Pypes X Pipe for v6 Conversion - $119
Old Jun 15, 2009 | 06:51 PM
Topless Stang
I was trying to work up a price if I pieced it together, but I must admit it went a little over my head. Please try to clarify..
From Header ------Mid Pipe-----???????----exhaust
The cheapest I found the boomtube axlebacks was for $319 from StangMods. Any linkage to a cheaper price point would be appreciated. The Pypes X Pipe is the only such pipe I found that connects to a stock v6 manifold. After that pipe u can fit any GT axleback kit...and it reuses your stock cats. I like in Pa and we have emissions testing. Any help is appreciated. Thanks!
Old Jun 17, 2009 | 07:01 AM
48prerunner's Avatar
48prerunner
you need an x pipe ( pypes or rock valley auto about $100) or h pipe ( used from a gt) like 4 liter said and a driverside over the axle pipe ( used form a gt I paid $15 for mine think napa only has pass side) and a band clamp (can get at napa for $12) and exhaust hangers and (4) 8mm bolts. (late model mustang about $50)
firecoyote
Sep 27, 2015 02:37 PM
Sep 17, 2015 07:32 PM
Sep 10, 2015 08:39 PM
vintageaion
Sep 8, 2015 10:45 AM
TimeLord101
Sep 4, 2015 09:27 AM
