engine
Old Sep 2, 2009 | 03:56 PM
stantheman123's Avatar
stantheman123
Default engine
my engine just went the other day on v6 4LT 2005 mustang ,white smoke from exhaust and overheated anyone know why a motor would go that fast on a 4year old car?
Old Sep 2, 2009 | 04:04 PM
ODDYSEY's Avatar
ODDYSEY
Site Moderator of Fury!
abuse, not maintaining the fluid levels, bad gasket, there could be any reason.
Old Sep 2, 2009 | 04:37 PM
stantheman123
always did oil changes alls had all fluids up to par no abose that i know of iam a retired driver 55, dont abuse my car
Old Sep 2, 2009 | 05:33 PM
Joshspony's Avatar
Joshspony
well, if you've regularly and accuratly maintaned the car then it must just be part failure. sounds like a bad head gasket or maybe even a cracked head.
Sometimes it just happens, unfortunatly if you don't fix it yourself it will probably be quite expensive.
Good luck
Old Sep 2, 2009 | 10:08 PM
ericyo's Avatar
ericyo
Yup that happend to mine too mine was cracked head. I just found a used engine with 4,400 miles on it... cheaper to do that then to replace the head gasket.
Old Sep 3, 2009 | 05:10 PM
Joshspony's Avatar
Joshspony
unfortunatly that may be the way to go
Old Sep 3, 2009 | 05:40 PM
drfister's Avatar
drfister
Stantheman123,
I see your from Ontario, not sure where abouts though. Check out www.gtamc.com that is a local forum. There was a guy a month or so ago selling a used 4.0 from a mustang with under 10,000kms for like $700-$1000. Also, check out DaSilva Racing (in Pickering) or Steeda in Milton. They might be able to hook you up with a new motor for cheep. I know DaSilva a little while ago also had a 4.0 for really cheap from someone doing a swap. Google them and give them a call, they will be able to help you out!
edit:
I dunno if you want a 3v 4.6 but $1800 includes motor mounts exhaust manifolds, driveshaft. obvsly you'll need a new rear end but just tryin to throw out some suggestions...
http://www.gtamc.com/forums/showthre...ighlight=motor
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
rksnow1
Sep 14, 2015 08:46 PM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
