Supercharging a v6 mustang
Old 10-27-2009, 11:05 AM
motoridr09
motoridr09's Avatar
Default Supercharging a v6 mustang
Hello. Im wanting to put a vortech supercharger on my 4.0L but before i do that i wanted to know how much other modifications i needed to do (exhaust, drivetrain,etc.) so i dont just tear apart my car. Any help will be much appreciated. Thanks.
motoridr09 is offline
Old 10-27-2009, 05:17 PM
Moderator
JimC's Avatar
You should consider upgrading the rear end to the 8.8 out of a GT. It is stronger than the 7.5 and depending upon your use of the car (maybe some track time with drag radials?) it will hold up better, plus it has the Tlok already.
I actually bent the pinion on my 7.5 when I was naturally aspirated with just an intake, tune and some drag radials on the car.
JimC is offline
Old 10-27-2009, 09:01 PM
staggolee
staggolee's Avatar
wow, didn't realize the 7.5 was that weak, might have to upgrade sooner than expected...
staggolee is offline
Old 10-28-2009, 11:00 PM
Rnstanger
Rnstanger's Avatar
When i put on my Vortech I don't think I upgraded anything else that should have been upgraded ie: 8.8 Rear end, Aluminum DS or anything else. Nothing has broke other than the motor. lol
Rnstanger is offline
Old 10-29-2009, 12:01 AM
tx_zstang
tx_zstang's Avatar
The rear end is the main thing you need to upgrade.
Other stuff is included with the vortech kit (fuel injectors, spark plugs, etc.).
Make sure you get a good tune; if buying a whole vortech kit, it'll come with a tuner and a tune, but a custom tune will be better. You can use the vortech tune to get you started though.
And good choice, the vortech kit I had has been very good to me for 2 years. (recently sold it to do a v8 swap).
[Where in of Texas are you?]
Once installed, you'll need to relearn how to drive the car: it'll be so much different!!!
tx_zstang is offline
Old 10-31-2009, 11:27 AM
Joshspony
Joshspony's Avatar
It seems like the x charger is the blower of choice for the v6ers on MF. Is there a + or - to the vortch vs the X? tx zstang, did I see on another thread that you've had them both?
Joshspony is offline
Gene K
10-21-2015 11:37 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
col2560
09-25-2015 08:59 PM
09-03-2015 07:14 PM
Quick Reply: Supercharging a v6 mustang
