misfire problem
I have a 2006 4.0 mustang and the other day i noticed that when i turn the key on my check engine light turns on and stays on then flashes, and if i sit in park for a while i can feel the car shake like it is a small misfire... I think it is either the fuel injectors or the spark plug wires, but could it be the cat converts? Can somebody give me their input on it... I dont want to put money into fixing the problem until I can figure out what it is... Thanks
If its flashing turn it off. Flashing generally means cam or massive mechanical issue.
Do you have any codes yet? may be a bad wire.
My gfs mustang had a wire drop on to the headers and it melted through it causing a misfire. but the engine light never flashed.
