Alternator problems at 38k miles.
Old Sep 26, 2010 | 11:54 AM
Nuke's Avatar
Nuke
Originally Posted by charlie32
Hi Guys. Remember---An Alt. is desighned to MAINTAIN batt. voltage NOT to charge a
dead batt. !! If you jump a dead batt--drive 10-15 min and then TRY to lay your hand on your Alt.---Is so HOT from overwork it will burn you. Always tricke charge a low batt for 21-14 hrs to bring it back to normal Do NOT try to regain the voltage by
trying to let the Alt do it !!
Correct in regards to the alternator NOT being used to bring a battery back to full charge from a deep discharge state. Although a trickle charger will eventually recharge a battery, a good 10-15 amp (or higher if you can afford it) AUTOMATIC battery charger is the best way to go. Quite often, wet cell batteries respond better to a higher initial charge rate (forced-feeding) than via a trickle charge.
Old Nov 5, 2010 | 11:52 AM
2007redfire's Avatar
2007redfire
your lucky it was just youre battery. I just had to replace the alternator and battery in my 07 which cost me 500, plus the 80 towing fee because the car was completely dead and couldnt even be jumped. Its just mod money going down the drain.
Old Nov 5, 2010 | 11:56 AM
Alec's Avatar
Alec
Depending on your insurance they might be able to reimburse that. Mine did.
Golfsito
Oct 6, 2015 11:02 AM
GimpyHSHS
Sep 18, 2015 12:27 PM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
robjh22
Suspension
Sep 8, 2015 12:47 PM
