Cai stack racing?
Old Nov 9, 2010 | 08:53 AM
67stangr's Avatar
67stangr
Default Cai stack racing?
Anyone have or know if the CAI from stack racing is worth buying?
Old Nov 9, 2010 | 10:18 AM
2005Redfire6's Avatar
2005Redfire6
If youre going for a No tune required CAI, its only like $20 less then the BBK and there is plenty that have used the BBK I would spend the extra $20 for piece of mind with the BBK then some pretty much unknown product.
Old Nov 10, 2010 | 11:03 PM
izzyocon's Avatar
izzyocon
hell no. the filter is tiny and won't flow much air. the tube is black metal and will absorb a ton of engine heat, therefore increasing your intake air temperature. you want a cold air not hot. a cold air intake is not worth buying unless it requires a tune. spend the extra money on a JLT intake and tune. you'll be happy you did
Old Nov 11, 2010 | 04:37 AM
Whitehorse10's Avatar
Whitehorse10
I've never heard of stack racing myself but I can tell you that just because the tube is black and metal does not mean it will absorb a ton of engine heat. The same is true for any CAI or for that matter the "black" plastic tube that comes on the stock intake. The fraction of a second that air spends traveling between the filter and the throttle body / intake plenum is no where near long enough to increase the air temperature from heat soak. Without a tune a CAI's only real purpose is to dress up your engine bay a little. It won't make a difference in your performance. If it does have a small filter than izzyocon could have a valid point as it might restrict your airflow somewhat but it all depends on how small it is.
Old Nov 11, 2010 | 06:23 AM
2005Redfire6
Just the BBK for me def. increased throttle response and change my exhaust tone a little.
Old Nov 11, 2010 | 06:44 AM
Nuke's Avatar
Nuke
Stack Racing is a known supplier of performance and dress-up parts. However, I'll bet that "their" CAI is made by someone else and all they do is re-badge it.
Spend the money on a tune-required CAI & custom tune combo. Any other CAI would be regretable.
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
mungodrums
Sep 28, 2015 10:54 PM
firecoyote
Sep 27, 2015 02:37 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
