header gaskets
Old Jan 19, 2011 | 08:06 PM
Gummy's Avatar
Gummy
Question header gaskets
hello all got a question for those you have installed shorty headers on their 4.0's have you guys use the supplied gaskets or have you used OEM ford gaskets Im getting ready to install my Pypes shorty headers but Im wondering which gaskets would be better to use.
Old Jan 19, 2011 | 09:18 PM
MadStang40's Avatar
MadStang40
I didn't have the equipment to install the headers, so I took it to the shop that did my cat back. They told me that the supplied gaskets weren't needed and they could use the gaskets originally on the car. It's been about a week now and I've yet to have an exhaust leak or rattle (knocks on wood). [I also have the Pypes shorty headers]
Old Jan 19, 2011 | 10:24 PM
JCON's Avatar
JCON
The supplied ones are junk. Go to autozone and get a set of crush gaskets. The stock ones could be reused but I would just get a new set.
Old Jan 19, 2011 | 11:53 PM
Gummy's Avatar
Gummy
Also correct me if im wrong it's better to use the stock bolts right. so basically dont use the supplied hardware
Old Jan 20, 2011 | 02:24 PM
MadStang40's Avatar
MadStang40
Yessir, that's my opinion. If it's good enough for Ford OEM, it's good enough for me.
Old Jan 20, 2011 | 11:00 PM
JCON's Avatar
JCON
Yes, the bolt kit with the headers is as generic and craptastic generally as the gasket. If your bolts are in good shape reuse them, if not, check your block for stripped threads :X
Old Jan 21, 2011 | 09:42 PM
Nice Pony's Avatar
Nice Pony
Use all the stock hardware but don't reuse the gaskets. Get new stock gaskets. They are superior to all the aftermarket crap gaskets. For added security you could use NordLock washers but realistically they are probably not need when using the stock gaskets.
Old Jan 27, 2011 | 12:01 PM
Torch_Vert's Avatar
Torch_Vert
+1 to this. It is exactly what I did when installing my JBA's 3+ years ago. No leaks, no problems.
New factory gaskets and keep the stock studs and nuts
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Dathan
Oct 5, 2015 05:52 AM
junior04
Sep 28, 2015 10:53 AM
wraith777
Sep 28, 2015 10:49 AM
Demodulates
Sep 18, 2015 11:14 AM
