Tires
Old 05-16-2011, 03:16 PM
JCON
JCON's Avatar
245/35 on the fronts and 275/35 on the rear should be a good combo. The staggered sizes also give it a more aggressive stance.
JCON is offline
Old 05-16-2011, 06:24 PM
Warpig12354
Warpig12354's Avatar
Thanks!
Warpig12354 is offline
Old 05-16-2011, 06:55 PM
Warpig12354
What other tires should I get off that list? As NITTO doesn't make the front tire I want.
Old 05-16-2011, 08:10 PM
JCON
JCON's Avatar
This is a 255/35-18 which is for the front.
This is a 275/40-18 which would be for the rear
You could go larger in the rear if you wanted to, with this, a 295/45-18
Which list are you looking at?
JCON is offline
Old 05-17-2011, 07:13 AM
Warpig12354
It's the one in the link to the rims on the Elementwheels.com I wanted to buy all from the same place so I could get them mounted and balanced for free. I was looking at the Niche Circuit Matte black staggered 18x8 and 18x9.5 set, it's toward the bottom of the page and it's just a little dropdown bar thing.
EDIT: And are you sure those will fit? They seem really wide. Thanks again for all your help.
Old 05-17-2011, 07:54 AM
JCON
JCON's Avatar
I've heard good things about the Advan and Proxes but never used them. Also, looking at their prices, you may want to just consider having a shop do it and buy the tires from somewhere else. They're charging for (2) tires more than you would pay for (4) elsewhere. I just priced your wheels with Yokohama Advan Sports and the total is $2,611. About $700 too much. a mount and balance won't be anywhere near that.
JCON is offline
Old 05-17-2011, 07:56 AM
Warpig12354
Alright, i'll just get those NITTOs you showed me. Are you they'll fit right? Thanks.
Old 05-17-2011, 04:32 PM
JCON
JCON's Avatar
I double checked with a few other tire sites and they should fit. If you want to feel better you could email NITTO and ask them. You could also google 18x9.5 tire size.
I used NITTO's website under sizes and specs to find the largest for your wheel. Double check just to make sure im not blind.
http://nittotire.com/index.html#index.tire.nt555.sizes
JCON is offline
Old 05-17-2011, 06:22 PM
Warpig12354
Thanks, and what size do they start to rub at?
Old 05-17-2011, 06:28 PM
Warpig12354
I think a 255 might be a little too big for an 8" wide rim, right?
Quick Reply: Tires
