Coolent Leak
Old May 30, 2011 | 09:22 AM
2005Stang's Avatar
2005Stang
Default Coolent Leak
I have a leak and I can't tell where it is coming from. It is somwhere on the right or passenger side of engine. It doesnt appear to be a water pump. Thanks for help
Old May 30, 2011 | 09:37 AM
2005Redfire6's Avatar
2005Redfire6
If you are a little more specific it will help more to diagnose your problem!
Old May 30, 2011 | 12:43 PM
2005Stang's Avatar
2005Stang
It is running down the front of the block, also it is pooling on top of the engine, I jst noticed that last one. Not a big leak yet.
Old May 31, 2011 | 07:58 PM
Dineau's Avatar
Dineau
Check the thermostat housing, very common on those 4.0.
If you look at the front of the engine there's a big hose that comes from the radiator and it connects into a plastic housing with 3 bolts, see if it's leaking in this area
Old May 31, 2011 | 10:22 PM
2005Stang's Avatar
2005Stang
I found the leak, yup it is the thermostat housing. It is leaking out the back side of the housing. I ordered the housing from Rock Auto.
Old Jun 1, 2011 | 09:50 AM
2005Redfire6
Interesting, I'll keep that in mind!
Glad you have an easy fix!
Old Jun 3, 2011 | 10:49 PM
2005Stang's Avatar
2005Stang
I recieved the parts, but I figured the O rings would come with it. I am gonna check my auto parts store tomorrow if I can get them there. the were Motercraft parts
Old Jun 3, 2011 | 11:21 PM
2005Redfire6
They should, my local auto part store has a whole ton of o-ring types! Good luck.
4cylinderplus2
Oct 9, 2020 07:45 PM
bradleyb
Nov 27, 2015 07:50 PM
jerrytubes
Oct 23, 2015 12:11 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
wraith777
Sep 28, 2015 10:49 AM
