shift light install
Old Jun 25, 2011 | 04:50 PM
Sean-V6-Adams's Avatar
Sean-V6-Adams
Default shift light install
I have a 2010 V6 and I bought my friends Autometer Pro Shift lite, I mounted it and ran the wires except the green wire witch I think, but I'm not sure, goes to the coil but I don't know can anyone help?
P.S. I will post pictures when its done.
Old Jun 28, 2011 | 11:50 PM
Sean-V6-Adams
Old Jun 29, 2011 | 10:45 AM
2005Redfire6's Avatar
2005Redfire6
You may need the tach adapter in order to use that, on our cars you can't hook up a shift light the way you can with most cars.
http://www.autometer.com/cat_accesso...il.aspx?vid=99
Around $80
Old Jun 29, 2011 | 11:03 AM
Sean-V6-Adams
I plugged it into the far left wire on my coil and it works but for some reason is flickers between 1500 and 2000 rpms idk why my coil is sending a signal between those rpms
Old Jun 29, 2011 | 11:04 AM
157dB's Avatar
157dB
Cut & Paste Expert
Geen wire to coil.
And then just insert the "pill" and its done.
http://www.autometer.com/download_instruction/440B.pdf
Old Jun 29, 2011 | 03:25 PM
Sean-V6-Adams
157dB that doesnt work, thats exactly what i did and that is why it isnt working correctly. i do need the tach adapter to make it work, thanks redfire!
Old Jun 29, 2011 | 03:36 PM
2005Redfire6
Glad I could help!
Old Jun 29, 2011 | 03:39 PM
andywalls's Avatar
andywalls
is there any real reason why you need a shift light... even at 465rwhp i still have plenty of time to look at my tach... just throwing it out there...
Old Jun 29, 2011 | 03:40 PM
2005Redfire6
I think its more for so you don't have to look at the tach...
Old Jun 29, 2011 | 03:43 PM
andywalls's Avatar
andywalls
i understand the point just seems overkill... just saying...
