Engine swap
Old Jun 29, 2011 | 06:18 AM
Rshustler1's Avatar
Rshustler1
Default Engine swap
Hey guys I have a chance to buy a 90 cobra fully rebuilt, I was thinking of doing an engine swap is it possible? How easy? Would a mechanic be required for anythIng? Is it a direct swap? Has anyone done this?
Old Jun 29, 2011 | 03:39 PM
2005Redfire6's Avatar
2005Redfire6
You don't have to put the same thread in 2 different sections...
Old Jun 30, 2011 | 12:52 AM
Rshustler1's Avatar
Rshustler1
I didn't really know what section it was supposed to be in so I started with general and then after about a day of no response I went with tech and got a response, sorry
Old Jun 30, 2011 | 03:04 PM
pascal's Avatar
pascal
S197 Section Modder-ator
Sure, it bolts right up!
Get a bunch of duct tape, just in case.
Old Jun 30, 2011 | 04:08 PM
JCON's Avatar
JCON
Use the forum search and you will see how much time and money it is to just upgrade the S197 V6 to the S197 V8
Old Jul 2, 2011 | 12:11 AM
Rshustler1's Avatar
Rshustler1
What mods would need to be done? Obviously the motor mounts and would have to mod the drive shaft but what else?
Old Jul 2, 2011 | 11:18 AM
Ares05's Avatar
Ares05
don't you have to adjust the suspension for weight, new computer(I think), I have also heard wiring? these are just guesses
Old Jul 2, 2011 | 06:41 PM
MadStang40's Avatar
MadStang40
OP, search around the forum, there's a ton of threads on this topic. You're going to need motor mounts, a near rear end, new comp, and transmission. If you want to do it right, you'll get a new front suspension to hold the weight of the heavier motor and GT brakes to stop those ponies. As for the 90 cobra rebuilt motor, I have no idea if you'll have any clearance issues... You need to do A LOT of research.
Old Jul 2, 2011 | 07:01 PM
X3xMONGOOSEx3X's Avatar
X3xMONGOOSEx3X
There's plenty of room in the S197 engine bay for that motor. However motor mounts and just about everything else are gonna have to be a custom job. Good Luck!
Old Jul 3, 2011 | 12:31 AM
Rshustler1's Avatar
Rshustler1
It's not just a rebuilt motor it's an entire car , how hard will it be to get it my cars body on that comLetes suspension and drive train
