Auto Trans question
Old Dec 17, 2011 | 04:03 PM
CoupeKiller's Avatar
CoupeKiller
Cool Auto Trans question
OK, so I was showing my kid how to change the oil in a car (he's 11) and he accidently loosened the transmission fluid bolt. well needless to say, I was under there with him and just didn't notice he was doing it but caught it, but not before he drained about a 3/4 of a quart or maybe a little more. my question is, where the heck do I refill that fluid at because there is no transmission dip stick in the engine compartment....is this a dealer only thing?
Old Dec 17, 2011 | 04:25 PM
CoupeKiller
lol nevermind...dealer only...freakin owners manual says it cannot be added or checked by me. Has to go to the dealer because it is a sealed transmission..FML
Old Dec 17, 2011 | 10:11 PM
Mr. Ugly's Avatar
Mr. Ugly
No, you can refill it.
You should be able to google the directions.
Basically, you get a bottle of transmission fluid and a manual oil pump.
Stick a hose adapter into the center portion of the drain plug.
Add slightly more than what drained out.
Then let the excess drain back out until you get a very slow stream.
The pan and plug are designed to set your oil level properly that way.
Old Dec 18, 2011 | 02:18 PM
artsvettes73's Avatar
artsvettes73
Make sure the car is level when you do it. Pretty hard to do without a lift
Old Dec 19, 2011 | 08:56 PM
tx_zstang's Avatar
tx_zstang
Also, the trans drain plug is a plug inside a plug. Remove the inner one to full it, remove the larger/outer one will drain it all out.
The plug is designed do that the fluid level will be correct and even with the top of the inner-plug, when the car is running on level ground.
But yeah, getting fluid in from the bottom requires a pump to pump it up into the trans. You can use one of the cheapy mechanical fluid pumps at local auto stores.
Old Dec 31, 2011 | 01:56 PM
osco's Avatar
osco
Hey OP,,take your Kid with you through the entire process,,
Hope ya didn't bust His/her chops for that.
What yer Kid learns from you will save em thousands o bucks over a lifetime of
car ownership...
mtgldr
Feb 3, 2024 09:00 PM
97SN95GT
Sep 13, 2015 09:45 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
cbird1177711
Sep 3, 2015 08:43 PM
iculookin
Sep 2, 2015 12:34 PM
