Need help with failing cats
You'll rattle pop and bang your way to a sound violation at best, or a terrible headache whenever you take the car over 3k rpm.
Youtube some of videos of sixxers without cats, they sound terrible even with good mufflers.
Do you guys think the cats off of a wrecked car would be ok? Obviously it would depend on how bad of a wreck the car was in. I saw one online in Copart's inventory that looked it had just been rear ended pretty good. From the rear axle forward it looked pretty much intact.
No need for gaskets with that section of exhaust. Everything is compression. It's better to replace the entire midpipe than just the converters if at all possible. No cutting and welding that way. The mid-pipe from a wrecked car is fine as long as the pipe itself isn't damaged. 4.0 cats rarely fail. I wouldn't expect it to happen to you twice.
@Diabolical! I just ordered that Davico kit from that eBay link you posted. Looks like it's is everything from the flanges that bolt to the manifolds to the Y-pipe. Didn't really want to mess with having to take them off of a car at UPullIt and it probably wouldn't have been that much cheaper.
Thanks to everyone that posted. This was a huge help.
New problem: while changing out the throttle position sensor, one of the effin' bolts broke. Almost had the broken bolt drilled out of the throttle body when the drill bit breaks off in the hole. So, no way I can drill through the drill bit, I need a new throttle body. Anyone know where I can get just the body of the throttle body? Obviously, I have all the parts to put on another throttle body. How much might it be to get another TB from UPullIt?
I recently bought custom-fit cats for my V6. Walker muffler has an easy order page for specific fit cats. They have direct-fit cats for all cars. This is the 1-piece direct-fit cat for your car.
http://www.walkerexhaust.com/catalog...catalog-lookup
Walker does not sell direct to customers. I used Summit Racing:
http://www.summitracing.com/search?k...lk-50554&dds=1
$369
Walker's "info on Converters" page may help you understand Converters in general, and help decide what you should do.
http://www.walkerexhaust.com/support...ytic-converter
I hope this is useful
$369
I got magna flows direct fir cats for under $400. this is where I got them, price went up a bit though.
http://www.trucktune.com/product/magnaflow-23012
