how to bleed my radiator?
Old Jan 30, 2013 | 04:41 PM
cslix's Avatar
cslix
Default how to bleed my radiator?
My car heat isint getting very hot inside the cabin.. as the pin on the dash takes about 15 minutes of driving to meet the middle.. is there an easy trick to burp the radiator and get the air out with out doing anything big?
Old Jan 30, 2013 | 11:37 PM
MustangMikey04's Avatar
MustangMikey04
The Cheapo Manual (Haynes) says to fill the reservoir to cold line and run the car with the radiator cap off and squeeze the upper radiator hose periodically to clear air bubbles(preferably with a rag so u dont burn urself, and watch ur fingers around the pulleys). Once the car is at operating temp, turn off and let it get cold again and repeat the process until ur coolant is staying between the cold fill and full lines of the reservoir...this is pretty much all you can do bud. If this doesn't work I think its just too damn cold in NJ and it just takes time to warm up...time to move to Cali ;P.
Old Jan 31, 2013 | 05:45 AM
The01Cav's Avatar
The01Cav
These cars just take a little bit of time to warm up, My v6 is the same way it sat in the driveway for 15 minutes when I was trying to let the ice thaw on it and the gauge was just barely registering.
Old Jan 31, 2013 | 08:37 AM
157dB's Avatar
157dB
Cut & Paste Expert
This is how Ford says to do it...
It worked like a champ for me...
Old Jan 31, 2013 | 04:16 PM
cslix's Avatar
cslix
i dont even see where it says how to bleed it lol.. it just says use that tool that im not going to buy -_-
Old Feb 2, 2013 | 10:05 AM
157dB's Avatar
157dB
Cut & Paste Expert
Read between the lines.
Its called "filling and bleeding
WITHOUT the RADKITPLUS"...
I made me the 'tool'.
No need to BUY one...
Granatelli Sales
Jan 20, 2020 12:34 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Beerman309
Sep 19, 2015 01:16 AM
SteelerNation82
Sep 16, 2015 07:11 AM
MusicCity615
Sep 12, 2015 07:05 AM
