Old Oct 23, 2015, 01:34 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang Powertrain Guides
Print Wikipost
Rad Flush - Coolant Capacity?
Old Jul 4, 2013 | 03:46 PM
tamilrmx's Avatar
tamilrmx
Default Rad Flush - Coolant Capacity?
Hey guys, i wanted to drain out the coolant in the rad and re-fill it. I can't seem to find the re-fill capacity for rad drains. Does anyone know??
And i want to do the transmission fluid as well, pan drop and replace filter, how much fluid exactly will i need to feed back into the bottom bolt? And is there a specific fitting i need to buy? And is there a bolt i can remove on the side of the tranny to know when its getting overfilled or anything?
Details: 2007 Mustang V6 4.0L Automatic 104,000km
Old Jul 4, 2013 | 07:00 PM
Nuke's Avatar
Nuke
If you don't have the OM (where the info is), PM me with your e-mail and I'll forward the pdf.
Old Jul 26, 2013 | 07:43 PM
tamilrmx's Avatar
tamilrmx
UPDATE: Just putting it out there for people who want to do a 'radiator drain' on the 2005-2009 4.0L v6 models, its 8.0 litres that you need to successfully refill it back to the full cold line, once you let it bleed and let the heating fan come on, you will need another 400ml-500ml to top it off to the full cold line again
4cylinderplus2
Oct 9, 2020 07:45 PM
Granatelli Sales
Jan 20, 2020 12:34 AM
Nick Oliver
Oct 17, 2018 04:22 AM
wraith777
Sep 28, 2015 10:49 AM
MusicCity615
Sep 12, 2015 07:05 AM
