05 V6 with Manual Tranny Trouble....
I have an 05 V6 Convertible. She has 92K miles and is well treated. Recently she has had problems getting into first... Not smooth, fights it sometimes, but eventually gives in (with some gentle persuasion). I took her to my trusted shop and their diagnosis was that she was in need for a New Clutch. Painfully - She got a New Clutch. Now the Clutch feels great, but the same first gear problem persists.
Any suggestions? Am I looking at a Transmission Problem, Shift Linkage, something else?
Sal
Sal
IMO its the slave cylinder and that is all that was wrong with it in the first place.
Most likely the fluid was replaced since it drains out when you disconnect the line to pull the trans out. It can be plugged before too much leaks out but I don't see a shop bothering to do that. Since there is no bleader the best they can do now is drain the master cylinder.
My slave cylinder/throw out bearing went bad at 65K miles. I had the mechanic replace everything, except for the master cylinder. When I got my car back from the shop, I experienced rough shifting as well. I had them change out the transmission fluid and all is well!
Does your clutch pedal feel a lot lighter when pressing down?
My 07 4.0 does this as well. I never put much thought into it since its always been tough and hasn't gotten worse. My clutch always engages well and feels nice and stiff so I never thought it was the slave cylinder/throwout, and I have a short throw. The car does have about 84K miles though...trans fluid change helps? I'll have to try that!
My 09's clutch, flywheel, slave cylinder and throw out was replaced under warranty at about 35K. Right from day one, my clutch felt like I was driving an old truck, my leg would get tired in traffic. The tranny was real notchy going into first and the clutch would slip on hot days. When they took everything apart, my clutch was not pooched, but the flywheel was glazed. No one had an answer, so they did the replacement. Now my peddle feels just right (like my friend's 302), but at times it's still notchy going into first.
She is off warranty now, so I'm saving up for a MGW short throw shifter. I do run her at our 1/8 mile strip without problems (except power shifting into 3rd is a trip).
BTW, sometimes I get a weird clunk when I'm in first and let off the gas. Anyone have that problem? Oh ya and I do not ride my clutch!
