driveshaft removal
Old Oct 30, 2013 | 08:23 PM
ctross's Avatar
ctross
Default driveshaft removal
Hi, im in the process of removing my transmission and cant seem to get the driveshaft out. I removed 4 bolts from the transmission and 4 bolts from the the differential and cant seem to find any more, but its not budging at all.
any advice or am I missing something?
Old Oct 30, 2013 | 08:29 PM
dawson1112's Avatar
dawson1112
You should see a rubber or plastic boot on the drive shaft someplace, this is where the drive shaft should slide together to allow it to be removed. You may need to use a heavy mallet or dead blow hammer to persuade the ends to come loose so it will slide together enough to give clearance.
Old Oct 30, 2013 | 08:51 PM
ctross's Avatar
ctross
Thanks! I was hitting pretty hard with the deadblow hammer and getting nowhere, wanted to make sure I wasnt missing something. ended up using my scissor jack to get enough pressure to pry it loose.
now to figure out what & how to disconnect the clutch hydraulic line and the rest will be cake
Old Oct 31, 2013 | 12:36 PM
turbo 2.8's Avatar
turbo 2.8
clutch line has a clip on the black plastic piece on the transmission, you can use a small or thin blade screw driver to pry it back, then line comes right off. Don't lose the clip though, you'll need it.
Old Oct 31, 2013 | 08:15 PM
2005Redfire6's Avatar
2005Redfire6
I had a hard time getting mine off after removing the bolts due to the rust, I beat on it hard with a standard hammer and it came off.
Old Nov 1, 2013 | 02:42 PM
ctross's Avatar
ctross
when in doubt, hit it with a hammer
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
