Coolant Temperature Sensor
Old Dec 30, 2013 | 10:05 PM
eed's Avatar
eed
Default Coolant Temperature Sensor
Hello, I have a 2005 V6 and need to replace the coolant temperature sensor, I am not sure where it is located and was wondering if someone could point me in the right direction as far as what it takes to replace it.
Thank you
Old Dec 30, 2013 | 10:51 PM
Lethaldosage423's Avatar
Lethaldosage423
It's in the thermostat housing. In the valley (V) part of your engine in the front. It's brass with a plastic connector
Old Dec 31, 2013 | 01:28 PM
kevinmalec's Avatar
kevinmalec
You will most likely need to remove the thermostat housing in order to replace the new sensor. It was a bit challenging getting the sensor into the slot due to the rubber seal being big. My buddy had to use some force to squeeze it in!
Good luck!
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
svfetter
Oct 5, 2015 11:39 AM
Dathan
Oct 5, 2015 05:52 AM
wraith777
Sep 28, 2015 10:49 AM
