T5 cluster
I dont see how it would make a difference if the TB I have fits both the 3650 and my t5?
http://www.americanmuscle.com/exedy-...nder-0513.html
unless it wont bolt to the flex plate or the flywheel it should work fine correct?
10" but there was a change made in '07 I believe but I can't recall what it was. I think it may have been the flywheel. If you don't have the recessed surface area you may be able to run the 10.4 if it clears the bolts. This is my flywheel
It adds up fast that's for sure. If you can match the new clutch plate design with the old one then it should be fine. I just replaced the CenterForce dual friction plate with McCloed's 26 spline dual friction plate and kept the CF pressure plate. I first resurfaced the flywheel with an 80 sanding disk on my angle die-grinder.
Ok so I just ordered the same dual friction 26 spline clutch plate from mcloed. Its funny cause it is measuring just under 10" its like 9 11/16 but it should work just fine. I also ordered the 1-4 gear set from gforce and they should be in route here pretty soon. Hoping to get the parts within a month so I can get this dam thing going again. Thanks for your help jim
Yea, it may actually be metric sized so as long as it fits inside the ring you're good. Let me know how it works out.
Post the p/n for the plate you ordered so we have it logged in this thread. I didn't find my receipt so I have to dig up the box and see if it has the p/n.
Without a new 5th gear your going to have a big drop off in rpm, too low for normal cruising in the 50 - 65mph range, especially if you're pulling a hill. Around town cruising is fine and if you can cross over to the high cruising speed quickly you'll be ok. BTW, what are you doing in Italy?
I am in the army. Got a year left over here. There is no speed limit here so im not one to cruise @ 50-60. even though I have no idea how fast im going due to my 4.10s. But yea as soon as I get my package ill log the P/N
What mods, you must have a tuner to push 305rwh? I thought all the handhelds allowed you to set the update the axle ratio?
