Heater motor speed problem
Old Aug 6, 2017 | 01:24 PM
jimbir's Avatar
jimbir
Default Heater motor speed problem
I have a 2006 V6 mustang. The heater/AC blower motor only operates on the high speed setting. What is the likely cause? How would I diagnose the problem? I know there is a motor resistor. Where is it located?
Thanks> Jim B.
Old Aug 6, 2017 | 07:54 PM
imp's Avatar
imp
Thanks> Jim B.
As a general rule of thumb, the resistor bank is placed where it can be exposed to the moving air within the plenum. Resistors generate heat; carrying it away via air movement allows use of less expensive resistors. Unfortunately, such location makes them also quite inaccessible sometimes. I am not familiar with the 2006, sorry.
Try searching 2006 Mustang resistor location. imp
Old Aug 7, 2017 | 01:44 PM
Derf00's Avatar
Derf00
Gentleman's Relish
http://iihs.net/fsm/?d=336&f=Blower%...20Resistor.pdf
Haven't needed to change it on mine but looks easy-peasy. Under the passenger side dash (above the floor) to the right of the blower motor, close to the passenger kick panel.
Old Aug 8, 2017 | 06:53 AM
jimbir's Avatar
jimbir
Default Heater motor resistor
I found it and replaced it.
Here is my procedure.
Jim
Changing the heater motor resistor on a 2006 Mustang.
If your heater motor only works on the high setting, you probably need to replace the resistor provided the motor works at all.
The resistor is located to the right of the heater motor on the bottom of the plenum behind the glove box. I found the most convenient way to gain access to it is to remove the glove box completely. Open the box, empty it, and close it. Remove the 4 screws from the hinge (you'll need a 7 mm socket to do this). Open the box and push in on both sides to release the stops. The box should fall out into your hands. The resistor is the small connector closest to the glove box. Push in on the tab on the connector and pull it down to disconnect it. There are 2 screws holding the resistor to the plenum. Remove them (you'll need an 8 mm socket for this). The resistor will drop out of the plenum.
I checked mine with an ohm meter and found that the reading between any 2 pins was either OL (open line) or 0.0 (shorted), both of which means deceased. Advanced Auto parts had one in stock (BWM #RU1133 for $25.49 + tax). If you're patient, you can get them for less than that on line. I told the clerk I was going to plug it in in the parking lot and, if it didn't work, could I bring it back? (An advantage to dealing with the store.) He said yes. It worked.
There are 2 guide rails on the plug so it can only installed 1 way. Push it in till it clicks. There are 2 locating pins protruding from the plenum so that the resistor can only be installed 1 way. Insert it into the plenum with the tab on the connector facing the center of the car. Position it on the locating pins and install the 2 screws.
The trick to installing the glove box is to position it in the opening, push in on the sides so they enter the opening, line the top of the box with the top of the opening, and close it till it latches. Now you don't have to juggle it while you install the hinge screws,
This was my experience with my 2006 Mustang. I would think that this would work with any model year between 2005 and 2008. If you're young and really, really flexible, you might get away without removing the glove box.
8/8/2017
Jim Birke
jhawkr
Oct 13, 2016 10:15 AM
DaveGlasscoc
Sep 27, 2016 08:07 AM
ArchNemesis
Aug 4, 2016 08:19 PM
Wellthatsbroken
Jul 25, 2016 01:04 PM
