PO106 and PO401
Old 10-21-2018, 05:13 PM
JonU
JonU's Avatar
Default PO106 and PO401
Just swapped out the plug wires w/Motorcraft set at 130k and now have a CEL w/ the following codes:P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/PerformanceP0401 Exhaust Gas Recirculation Flow Insufficient Detected
Just a coincidence or did I knock something loose while installing the wires? I'm not seeing any obvious cracked/disconnected hoses or loose connectors at this point.
Any suggestions?
Thanks!
Jon
JonU is offline
Old 10-22-2018, 04:36 AM
08'MustangDude
Banned
08'MustangDude's Avatar
You had to have knocked something loose, wire harnesses or broke some wires...
A plug wire change would not cause that.
This is the EGR w/MAP Sensor:
Check the harness and hoses.
I think someone said the EGR and MAP are one unit...
08'MustangDude is offline
Old 10-23-2018, 11:08 AM
JonU
JonU's Avatar
Thanks. I'm not seeing anything obvious, and although changing out the plug wires was a hassle, there wasn't any serious yanking and tugging involved.
I'll get a hold of Tasca and order an EGR unit. I was just concerned because there are a few posts where replacing the EGR unit didn't cure the CEL popping up.
JonU is offline
dust180
06-14-2016 01:56 AM
1987notchback
12-19-2011 07:23 AM
whitestang86
09-27-2007 12:20 AM
99StangGTTN
06-15-2007 11:50 AM
1BADASSLX
02-21-2006 03:05 PM
Quick Reply: PO106 and PO401
