2005 V6 hot/warm start problem
Hello everyone!I've got one issue that is bugging me,that happen only when i warm/hot start the car..when i turn it on,the car will suddenly idle really bad,stall and die right away..if i don't give it a little bit of throttle,the car keeps dying..otherwise,when cold starting,the car start perfectly fine. Everything started one and a half year ago,when the PCM died on me..first,the idle was a mess but it wasn't doing stuff like that..and then,little by little,we came to this point..i've managed to finally replace it and get everything working again in October of the last year,but now I'm in this situation..I've just swapped the MAF with an OEM motorcraft one,IAT swapped a few weeks ago with a new one,the throttle body is completely new(I've changed it a couple of months ago because the idle screw broke,and so I've got also a new TPS)... anybody have any clue on what could cause the issue??already checked all the vacuum and there's none 👍..mine is a 2005 V6 supercharged with an x-charger Xtreme intercooled.
