am i just being paranoid?
RE: am i just being paranoid?
How long has it been going on... I mean hell I smell gasoline ocassionally on startups.
If this continues to happen, get it checked out, but otherwise, it happens to everyone on a rar occassion.
well since it is winter it sits a lot would that have anything to do with it? spark plugs wouldnt cause this right? I did the spark plug install a week and a half ago. Then two days ago on startup it would be faint then go away and now it does it while idiling. I had to slightly rotate the fuel injectors to get at the plugs could this have caused it? I moved them back to where they were before.
Its been said that when you get a bigger MAF that your car will run richer than normal and when you sit at an idle its kinda like having a cammed out carb car you have to clean it out everyonce in a while but your car would be fine at idle its fine its just cause the MAF
