valve stem problem
at the tire shop i used to work at we had a tool that you screwed onto the end of the valve stem and pulled it thru the hole. There are different valve stems. Low pressure stems, high pressure stems, metal stems. They also have short/long stems. Long stems are for cars with hubcaps because you have to go thru the rim + some more. Low pressure stems (0-40psi) high pressure stems(0-100psi) metal stems ive seen are usually on limo caddys and those are filled to 80psi.
TfcCDR
Sep 14, 2015 12:08 PM
zanemoseley
Sep 6, 2015 12:58 PM
