procharger
Old 03-05-2006, 02:04 PM
detroitmach
detroitmach's Avatar
Default procharger
Im looking to get a procharger p-1sc with intercooler for my 03 mach 1, I was wondering how many pounds of boost would be safe to run with the stock block.
detroitmach is offline
Old 03-05-2006, 02:32 PM
dfault
dfault's Avatar
Default RE: procharger
i've been looking into the same kit for my 04 mach. Through the research i've done, 8 psi is the most you will want to go to be safe. and that is if you have a safe tune. when i get mine i'm going to run 6 psi at first so the engine will hold up until i can get beefed up internals. It just depends how much you drive it and how long you want it before you change more things.
dfault is offline
Old 03-05-2006, 02:42 PM
detroitmach
I was thinking the same thing. I talked to the shop where i will be having it tuned and they said 8psi would not be a problem at all. They told me the most they would go would be 12, but to me that sounds a little to high. So i think im going to go with 8 and a safe tune for now.
Old 03-05-2006, 02:52 PM
dfault
dfault's Avatar
yes, that would be smarter than 12 psi LOL. with 8 psi you will be putting down alot of power that you will be happy with. Is your car stock?
dfault is offline
Old 03-05-2006, 03:51 PM
detroitmach
Pritty much, I have a 4.10 slp cat back, k&n filter, B&M shifter, and I am going to be ordering GMS lower control arms sometime this week for it.
Old 03-05-2006, 03:52 PM
01saleen144
01saleen144's Avatar
just installed the p1sc-2 on an 01 saleen. Stock block, running it at 10 psi. Made 426/425. U should be ok at that. Plus, doesnt the mach one have forged internals already?? Im not sure, but i thought they did??
01saleen144 is offline
Old 03-05-2006, 03:55 PM
monkeydude3
monkeydude3's Avatar
from what i understand the mach one and cobra engine are essentially the same, however the mach has non forged internals (because it is N/A so they cut some cost on using regular internals) and the cobra engines (that are s/c) have forged...
that's what I've always thought, correct me if I'm wrong
monkeydude3 is offline
Old 03-05-2006, 04:00 PM
detroitmach
Yeah no forged internals for the mach, at least i know the pistons and rods are not. I have herd from someone that the crank is but im not 100% sure, kinda bad seeing how I own one and everything.
Old 03-05-2006, 04:45 PM
Davojan59
Davojan59's Avatar
if ur mach 1 is a 5 speed then u DO have a forged crank and thats about it. if it an aod then nothing is forged.
Davojan59 is offline
Old 03-05-2006, 04:53 PM
antiv6
antiv6's Avatar
ya 5-speed is forged and auto is cast flywheel. 8 psi is what i would use if i ever supercharged it
antiv6 is offline
Quick Reply: procharger
