Is the 75MM Throttle and Pleanum bad ?
RE: Is the 75MM Throttle and Pleanum bad ?
ORIGINAL: code3GT
Or if you don't car about the "Bling Factor"...get the C&L plenum with BBK 75mm TB.
ORIGINAL: rbstang
get the accufab plenum/75mm tb combo... you wont regret it.
ORIGINAL: GrayGhost01GT
Does the Cl pleanum and bbk Throttle body put out anymore power?
Check the 4.6 tech sticky on the top of the page. There is a comparison of the combos
ORIGINAL: code3GT
says who?
ORIGINAL: travisl1213
its not gonna hurt but it wont do to much more than the 70 w/o F/I
says who?
The most difference i have ever seen on a mild N/A setup going from a stocker to 75 was 2 RWHP. I wouldn't think there would be much difference???
I am running a 70 and don't plan on changing it with the blower. The only reason I would is if I came across a good deal on a 75 and the fact that the C&L plenum specifys a 75mm.
ORIGINAL: 2000GT4.6
I have seen blower setups where swapping from a stocker to a 75 only made a 5 or so RWHP difference.
ORIGINAL: code3GT
says who?
says who?
Yeah, my point is for the cost difference from 70-75mm, get the 75. Also, FYI 2000...on the Mrs' Stang with her Vortech, we saw +6 rwhp going from a 70 to a 75 @ 10psi and 9rwhp @ 14psi
Hey guys I just checked the Thread on Throttle Bodys and Pleanums the Accufab beat the C&L by 1 hp and the torque by 4 pds of torque ,but where they using a C&L Throttle body? I think they where using the 70MM Do you think the BBK 75 THROTTLE BODY WOULD SURPASS the Accufab? With the C&L Pleanum?
ORIGINAL: code3GT
ORIGINAL: rbstang
Thanks Guys, Imma go purchase my BBK 75 MM Throttle body and C&L pleanum I will update you guys how I like it once I get it installed next week! Could I do the install myself Im a beginner mechanic lol so not really good yet! Im scared since I have heard that you can mess up your Idle and throttle response do you think I should leave this install for my mechanic?
