check engine codes
Old Mar 6, 2006 | 05:33 PM
1nsanegt's Avatar
1nsanegt
Default check engine codes
was like whoa!!
Purge Valve C Fault
P1451
P0135
P1409
P0141
P0161
Old Mar 6, 2006 | 09:18 PM
red2k1gt's Avatar
red2k1gt
Default RE: check engine codes
P1451 EVAP Control System Canister Vent Solenoid Circuit Malfunction
P1409? EGR Vacuum Regulator circuit malfunction
P1409? Electronic Vacuum Regulator Control circuit fault
I dont know what the other ones are, or even if you were asking what those were but heres what I found for you. Hope this helps
Old Mar 6, 2006 | 09:21 PM
1nsanegt's Avatar
1nsanegt
do i have to go to a dealer for these?
rbstang's Avatar
rbstang
A code P1451 may mean that one or more of the following has happened:
* VPWR circuit open
* Damaged canister vent solenoid
* Canister vent solenoid circuit open or shorted to ground, power, etc.
* Damaged Powertrain Control Module (PCM)
Possible Solutions
* Verify canister vent solenoid - To verify normal functioning, monitor the EVAP canister vent solenoid signal PID EVAPCV and the signal voltage (PCM control side). With the valve open, EVAPCV indicates 0% duty cycle and a voltage approximately equal to battery voltage. When the valve is commanded fully closed, EVAPCV indicates 100% duty cycle, and a minimum voltage drop of 4 volts is normal. Output test mode may be used to switch output on/off to verify function.
* Replace canister vent solenoid
P0135 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P1409 Electronic Vacuum Regulator Control circuit fault
P0141 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0161 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
Old Mar 6, 2006 | 09:37 PM
red2k1gt's Avatar
red2k1gt
sounds like you got a burnt out solenoid and a pair of 02 sensors. If you dont feel like messing with the repairs then sure you could take it to a shop, but these repairs are easy enough that you could do them yourself if you wanted to
ps- good find on the codes rb, you are a greater searcher than I
Old Mar 6, 2006 | 09:39 PM
rbstang's Avatar
rbstang
eh i have no life.
Old Mar 6, 2006 | 10:53 PM
1nsanegt's Avatar
1nsanegt
i dont know the location of P1451... P1409
the 02 im assuming they are on the headers? or? the midpipe? maybe the cat-back?
and 02 sensor why is there 4? is there 4 different sensors?
and damn, is this going to be costly?
also whats this..
Vehicle scann
control system
Purge Valve C fault
Old Mar 6, 2006 | 11:00 PM
rbstang's Avatar
rbstang
ORIGINAL: 1nsanegt
also whats this..
Vehicle scann
control system
Purge Valve C fault
2 o2 sensors before cats and 2 o2 sensors after the cats.
Old Mar 6, 2006 | 11:04 PM
1nsanegt's Avatar
1nsanegt
thank you ill get on that 2morrow, what baout the other 2 sensors? and thie purge valve thingy?
Old Mar 6, 2006 | 11:12 PM
rbstang's Avatar
rbstang
no clue luckly i havent run into that problem.
