Emergency pt 2
Emergency pt 2
Ok guys, I have everything hooked up running ok except when i went to get in my car I dident have no pedal it was all the way down and I think ive done something wrong with the throttle. How do you hook the throttle to the BBK 75 MM Throttle body? And where is the proper location?
Thanks,
Thanks,
RE: Emergency pt 2
Like silver said..it goes around and all the way in the hole. If it stays in and looks normal, you did it right. There's also a spring from that throttle cable bracket to the tb that has to be connected.
RE: Emergency pt 2
[IMG][/IMG][img=http://img52.imageshack.us/img52/1592/picture0021zk.th.jpg][IMG][/IMG][img=http://img72.imageshack.us/img72/3153/picture0038dp.th.jpg]
Hey guys sorry the pics arent too well they where taken tonight! Sorry can any one tell me if Ive connected my pedal cable correctly to the throttle? ITs the little silver thing inside the gold! Is that where its supposed to go?
RE: Emergency pt 2
I can't really tell from the pic but the cable is supposed to go through that grove and into the hole or whatever keeps it in. Kinda hard to explain.
Where are you located? I'm about to go over there and give you a hand. lol
RE: Emergency pt 2
It looks like the cable is not in the groove.
To install the throttle cable you need to hand open the throttle body, hold it open, thread the throttle cable through the thottle body cam, and THEN into the barrel retainer. If you jump right to the barrel retainer you won't take up the slack in the pedal.
