Dyno run on stock GT to give you guys a good base!
RE: DYNO RUN FOR STOCK GUYS LOOK HERE FIXED!
umm no, if you checked out his stock numbers he only showed like 187 at the wheels before he supercharged it
and the other kid had a lot done to his trannie, reducing power loss from the flywheel. and the fact that he put in a lighter flywheel helps too.
thanks bud i can read i said that in the last post if you actually read i was talking about tw diff people. but i guess your not paying that close attention you jsut want to say how a 5 speed pulls more power when the dam kid puts like a grand into his car of course your gonna see 20 horse more. its not the 5 speed its the 1000 dollars of mods pal.
ORIGINAL: 03redGT
Flowmaster American Thunder Catback
13lb. Aluminum Flywheel
Spec Stage2 Clutch
Clutch Adjuster Kit
Steeda Tri-Ax
What $1000 mods are you talking about? I didn't know the Flowmaster is $1000!!!!!!!!!!
ORIGINAL: 03redGT
Spec Stage2 Clutch
Clutch Adjuster Kit
Steeda Tri-Ax
Spec Stage2 Clutch
Clutch Adjuster Kit
Steeda Tri-Ax
you see that stuff there its expensive look into it[sm=bicker.gif][sm=icon_rtfm.gif]
ORIGINAL: 03redGT
no reason to curse pal but obviously your illiterate
Spec Stage2 Clutch
Clutch Adjuster Kit
Steeda Tri-Ax
Spec Stage2 Clutch
Clutch Adjuster Kit
Steeda Tri-Ax
actually if you were smart you'd know that all those trannie parts once again "free up HP to the rear wheels" second time i had to tell you buddy
