Changing spark plugs
Old Mar 12, 2006 | 04:18 PM
hawwk11's Avatar
hawwk11
Default Changing spark plugs
I need help changing the spark plugs in my 99 GT, i need to know ho because i have never did it before. Is there a special tool needed? Where exactly are the plugs located?
Thanx,
Old Mar 12, 2006 | 04:32 PM
code3GT's Avatar
code3GT
Mustang Nazi
Default RE: Changing spark plugs
They are under the coils which are directly under the fuel rails. There are 2 (If I remember correctly 8mm) bolts on each coil. Just wiggle them from under the fuel rail. The spark plugs will be 5/8. Remove the plugs, gap the new ones and reassemble opposite from removal.
Old Mar 12, 2006 | 04:44 PM
hawwk11's Avatar
hawwk11
Thanks alot Code.
ORIGINAL: code3GT
Old Mar 12, 2006 | 06:06 PM
redfireshaker06's Avatar
redfireshaker06
Theres one bolt on each coil
Old Mar 12, 2006 | 06:27 PM
statichead2k's Avatar
statichead2k
With aluminum heads you should use a dab of anti-seize on the plug threads to keep them from galling.
Old Mar 12, 2006 | 07:17 PM
justingt's Avatar
justingt
Yea anti seize those suckers up and remember cylinder eight (farthest one back on the intake side) is a bitch but it will come out. You'll need a special spark plug socket (5/8") and you'll appreciate an extension (i used a 9 inch). If you get iridium plugs no need to gap unless you have forced induction or something like that.
Old Mar 12, 2006 | 08:15 PM
Brute03's Avatar
Brute03
is it a must to gap the plugs on a stock car? i forgot to pick up a gapper
Old Mar 12, 2006 | 10:01 PM
Crystal's Avatar
Crystal
Always check them to be sure.
Granatelli Sales
Mar 25, 2016 08:01 PM
2007StangV6
Jan 28, 2016 06:09 PM
Granatelli Sales
Dec 27, 2015 06:28 PM
Emblazoned
Sep 3, 2015 10:45 PM
