98 gt
Old 03-14-2006, 01:08 PM
notdead
notdead's Avatar
Default 98 gt
if u did a PI head and intake swap. with new cam and off road hpipe and catback. would the car dyno around 300 hp.
notdead is offline
Old 03-14-2006, 02:31 PM
notdead
notdead's Avatar
Default RE: 98 gt
is it that no one knows [sm=dontgetit.gif]
notdead is offline
Old 03-14-2006, 02:33 PM
xx9gt6xx
xx9gt6xx's Avatar
Default RE: 98 gt
No....
You'd be closer to 300 at the crank...
xx9gt6xx is offline
Old 03-14-2006, 02:36 PM
notdead
notdead's Avatar
Default RE: 98 gt
k thanks
notdead is offline
Old 03-14-2006, 03:52 PM
travisl1213
travisl1213's Avatar
Default RE: 98 gt
prob 260ish to the wheels
travisl1213 is offline
Old 03-14-2006, 04:10 PM
notdead
notdead's Avatar
Default RE: 98 gt
i was just asking cuz my friend has one that dynoed around 300. he bought from his dad and his dad ddnt do anything to it. all my friend did was the off road pipe and catback. so i thought either pi swap or a cobra engine is in it, but the upper intake dsnt have a cobra emblem so im stumped.
notdead is offline
Old 03-14-2006, 04:16 PM
code3GT
Mustang Nazi
code3GT's Avatar
Default RE: 98 gt
There is NO way he dynoed 300 HP at the wheels with a PI swap. My guess would be around 230.
code3GT is offline
Old 03-14-2006, 04:19 PM
XxphantomsnypzxX
XxphantomsnypzxX's Avatar
Default RE: 98 gt
with aftermarket cams too, I would guess about 300 at the crank also, the raised compression helps, an article I read says the intake adds 35RWHP, the heads only add about 10RWHP, I forgot how much the cams give, but then again your using aftermarket cams. If you want 300 at the wheels may I suggest do this and some N20 to use with that raised compression
XxphantomsnypzxX is offline
Old 03-14-2006, 04:24 PM
notdead
notdead's Avatar
Default RE: 98 gt
im not sure wuts with the car but maybe it was a little under 300 but ill ask. ive heard that some cobra engines came in gt bodys, could that be it?
notdead is offline
Old 03-14-2006, 04:44 PM
gt96stang
gt96stang's Avatar
Default RE: 98 gt
no...unless someone swapped it in there..
gt96stang is offline
