CEL
Old Mar 21, 2006 | 07:58 PM
jlauth's Avatar
jlauth
Default CEL
My car is throwing a CEL i had it read at auto zone. It was a bank 2 lean code. I have had probs with the CEL as soon as i started with the O/R H pipe. I have MILs, but i may have a bad O2 sensor. Do you think that this code could be comming from the O2s or am i really running lean? When i had my car dynoed a while back it ran super rich like high 10s low 11s in AFR. I was also going to ask what is the easiest way to fing out which O2 is bad or should i just change them all?
Old Mar 21, 2006 | 08:21 PM
01BlueCobraVert's Avatar
01BlueCobraVert
Default RE: CEL
When they run the computer they can tell you what side. Alot of people believe it or not do not know how to properly use those things. Where I live the people at auto zone know nothing. Find someone who knows how to use the scanner and then call Ford with the specs. I think mine was running rich when I put my H-pipe on with a bad O2.
Old Mar 21, 2006 | 08:28 PM
jlauth's Avatar
jlauth
Default RE: CEL
Yea man you are prob right, because i had my car on the dyno last year and was running rich as hell, but because i just installed my NX kit i want to make sure that it is running perfect.
Old Mar 21, 2006 | 08:33 PM
01BlueCobraVert
Default RE: CEL
Both my rear O2's went after the H-pipe install. It took about a month for both to go. But I think they were the originals
Old Mar 21, 2006 | 08:51 PM
2000GT4.6's Avatar
2000GT4.6
Default RE: CEL
ORIGINAL: jlauth
On a N/A car? Yuck! You need a tune, problem will most likely go away after that.
Old Mar 22, 2006 | 12:59 AM
jlauth's Avatar
jlauth
Default RE: CEL
i know i need a tune i hope to get an SCT soon, but i just dropped a ton of cash on the NX kit.
Old Mar 22, 2006 | 08:19 PM
hurleymasta's Avatar
hurleymasta
Default RE: CEL
i would get a tuner rather than 4 new oxygen sensors, 4 new would be like over 200 bucks....tune you could shut off the rear 02's then sell your mils!
Ryan
Old Mar 22, 2006 | 09:50 PM
ghoste's Avatar
ghoste
Default RE: CEL
ORIGINAL: hurleymasta
Ryan
superb!
bryan616fl
Jan 25, 2019 09:07 PM
Urambo Tauro
Jun 10, 2016 03:28 AM
Scottyboy187
SVT Forums
Nov 20, 2015 02:57 PM
Scottyboy187
Nov 5, 2015 04:18 PM
BlackShelbyGt500
Aug 10, 2015 11:50 AM
