TUNER INFO
TUNER INFO
rbstang did the research and did an awesome job.
Superchips Max Micro Tuner
Price - $399.99
Tuner Options:
* Raise Speed Limiter
* WOT Shift Pressure
* Part throttle shift firmness
* RPM Shift Points
* Rev Limiter
* Cooling Fan ON/OFF Temperatures
* Re-Calibrate Speedometer for Gear and Tire Size Changes
Premade Tune from superchips.
50 State Smog Legal
You CAN NOT make your own tune with this tuner.
__________________________________________________ __________________________________________________ ______________________________
Hypertech III Tuner
Price - $339.99 - $399.99
Tuner Options:
* RPM Shift Points
* Rev Limiter
Premade Tune from hypertech.
50 State Smog Legal
DiabloSport Predator Tuner
Price - $399.99
Tuner Options:
* Dual timing adjustment points (2000-4000 RPM / 4000-7000 RPM)
* Timing table (+10% / -40%)
* Dual fuel adjustment points (2000-4000 RPM / 4000-7000 RPM)
* Fuel table (+40% / -15%)
* Idle (+/- 20%)
* On/Off switch for Traction Control
* Rev Limiter
* RPM Shift Points
* Torque Modulation (for better shift feel)
* Rear Oxygen sensor disable (use for off-road vehicles only)
* Disable EGR (use for off-road vehicles only)
* All of these parameters can be adjusted on the DiabloSport tune and/or the factory tune
49 State Legal
This tuner has a live data logging feature and diagnostics. You can use the diagnostic tool regardless
if the tuner has been locked or not.
SCT X Caliber II
Price $379.99-$410.99
Tuner Options:
* FUEL ADJUSTMENT(WOT: 6% Leaner to 14% Richer)
* SPARK ADJUSTMENT (Global Spark: -5 to +5 degrees)
* RPM Adjustment Spark(0 - 2000RPM: -14 to +4 degrees, 2000 - 4000RPM: -8 to +4 degrees, 4000 - 8000RPM: -8 to +4 degrees)
* TROUBLE CODES(Diagnose Check Engine Lights & Clear Trouble Codes)
* AXLE RATIO SELECTION(2.73 to 5.14 Ratios)
* MAF SELECTION(80mm to 90mm Lightning, SCT Big Air BA-2400 & BA-2800 MAF Meters)
* TIRE SIZE SELECTION(205/65/15 to 315/35/19)
* FUEL INJECTIOR SELECTION(19lb to 60lb Fuel Injectors)
* Idle RPM(-300 to +300RPM)
* Cooling Fan(On / Off Temp)
* Traction Control (On / Off)
* Two Step(On / Off & RPM)
* SHIFT ADJUSTMENT(WOT 1st - 2nd: -3 to +7mph, WOT 2nd - 3rd: -4 to +8mph, WOT 3rd - 4th: -5 to +10mph, WOT 4th - 5th: -5 to +10mph)
This tuner has a live data logging feature and diagnostics. This tuner has the most options then any other tuner on the market. You can have a custom tune made for your car from whoever you purchase the tuner through or you can make your own tune. This tuner can hold up to 3 tunes.
Price - $399.99
Tuner Options:
* RPM Shift Points
* Rev Limiter
50 State Smog Legal
Hypertech III Tuner
Tuner Options:
* RPM Shift Points
* Rev Limiter
50 State Smog Legal
Price - $399.99
Tuner Options:
* Idle (+/- 20%)
* Rev Limiter
* RPM Shift Points
49 State Legal
SCT X Caliber II
Tuner Options:
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
junior04
09-28-2015 10:53 AM
10mph, 2000, 300c, adjustment, diablosport, gt, larger, micro, mustang, predator, recalibrate, sct, selection, shift, size, sizes, speedometer, superchips, tire, tuner
