It's been awile...
#34
RE: It's been awile...
um u have an auto, its probably your torque converter, not the tranny itself. thats probably why u have to rev it so high to get it into a forward gear, cause its not building up enough pressure to shift into gears.
thats my best guess?
#35
You can't be serious...That has to be the most unsafe lift setup that I have ever seen!
Thank you for the pics though. I will post them on our accidental avoidance board at work.
#36
Really? It may look unsafe, until you rock the car with all of your strength side to side, then front to back.
But.. yeah you should post it, wouldnt want kids trying this at home.
#37
Just purchased HD2 TransGo High Performance Shift Kit & Heavy Duty Super Master Transmission Rebuild Kit
All gaskets for the complete rebuild
All rubber (lip seals, o-rings) and metal clad seals
Sealing Rings
Alto Red Eagle Clutches and Steel Plates
Heavy Duty Front Band
Complete Bushing Kit
Complete Thrust Washer Kit
Filter
Sealing Rings
Filter
#38
Domesticfan brings up a decent point... However, since his reverse works, and his FWD gears don't, that would lead me to believe it's not the T/C...
When you get it apart, check out the bands... Check out the pumps, and have the valve body 100% flushed if possible... I bet your problems will be cured afterwards...
On a side note, those Rims are bad ***.. What type are they??
JT
JT
