vacuum line issue
i went to run some seafoam through my car today, and had a hell of a time trying to get the vacuum line out (the one that runs into the TB). how hard should it be to get out?
i was mainly afraid of ruining the damn thing, as it seemed like the tube went in there pretty good. should i be worried about breaking anything?
Nice was very hard to get out also! I used some WD-40 Lubricant and used a flat head screw driver and gently slid it off! Take your time it will be find I love ur White GT with the Blue also by the way! Anyway you could get some pics up for us?
ORIGINAL: GrayGhost01GT
check out the attached picture... that is the line i was talking about. i meant plenum, not throttle body, as i described before.
rather than taking the tube completely off of the plenum, there is plastic line that runs into it - i was trying to remove it from there. there was a great tutorial that i saw where the person had done that.
[IMG]local://upfiles/22946/06828DAB5393482694D2B0EF448DF5E1.jpg[/IMG]
alright, finally got it... i wedged a flathead screwdriver head between the hose and the plastic rod while pulling each side... popped off after a bit.
was a bit disappointed with the results... didnt get much smoke at all. but i guess that is a good thing. 36k on an '01.
going to do another application in a couple days tho and finish off the bottle. im thinking maybe i didnt put enough in or let it sit long enough.
LivingInThePast
Sep 16, 2015 12:20 PM
TfcCDR
Sep 14, 2015 12:08 PM
