Having problems installing my chinspoiler!!
I know this may sound dumb. first i couldnt fit my drill underneath the bumper to drill out holes for the bolts i got. soo then i got the bright idea of pulling the car to the end of my drivay and let it hang off the edge soo that the bumper is only sticking over and then i got all the bolts in and now i cant get the side holes drilled for the last holes on the left and right side of the chin spoiler!! the drill is too long to fit underneatht he ground and the bumper. i tryed to jack it up but i cant get it to move up and down fair anough for it to start jacking up (if that made sence) any ideas??? btw it looks sweet.
RE: Having problems installing my chinspoiler!!
This is a 2 person isntall for sure, 3 rocks. Tape it where you want it and drill through the chin spoiler AND bumper.
P.S. Drive up on blocks of wood and then slide your jack under.
I did it alone, on a windy day. Tape the thing up a lot on one side, tape it alot on the other, then fill in the middle. Jack it up on one side with a jack (I used the stock jack) drill the holes you can, then jack the other side up and drill the holes.
I'm not sure what kinda tools you have, but you could always cut the drill bit to make it shorter. I used my stock jack to get the car up enough to get a 3-Ton jack under the front end. Once I had it up in the air I Duct-taped the spoiler in place. I adjusted it and drilled all of the holes by myself. Once you have the car in the air its not that bad. Keep working at it!
