Intake manifolds
Old Mar 31, 2006 | 03:20 AM
St4ng07's Avatar
St4ng07
Default Intake manifolds
On my 96' Gt. Would the PI intake help alot?Is it worth it to get it?Any conversions I would have to do?
Old Mar 31, 2006 | 03:32 AM
redstanger's Avatar
redstanger
Default RE: Intake manifolds
no. you would have to do a whole PI swap. this means that you would have to switch to PI heads and intake manifold. PI intake manifold will not fit on a NONPI head. The cheapest way to get power out of you car would be to find a set of used PI cams and swap just the cams. Thats a dynoed 15hp increase. You can pic up used PI cams for under $200. FYI im selling some with cam gears and everything fpr 175. its 175 mainly because their are $70 for just the cams gears which i have still in the boxes.pm me if interested.
this is a pic of my cams and gears/
http://putfile.com/pic.php?pic=3/8713535034.jpg&s=x11
this is more info on the cam idea.
http://www.modulardepot.com/articlesp.php?aid=12
Old Mar 31, 2006 | 04:22 AM
yoteehunter's Avatar
yoteehunter
You can do just the intake. Livernois sells a kit with adapter plates. The intake is realy the biggest restriction compared to the pi motor. If you have your car tuned after the swap you can and will see about 14-18rwhp depending on your current mods. It is a worth while swap and will defenetly help with power. You will be suprised if you swap in the cams with it, it will be so close to a pi it will be silly.
mrtrodonet
Sep 19, 2020 03:12 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
Dokilar
15
Oct 16, 2015 08:13 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
mustangheaven
Sep 29, 2015 11:00 AM
