make that hood scoop functional
im planning on drilling out under my scoop and making a fiberglass passage to my air intake. has anyone thought about this. i can get it up no problem, i was just looking for ideas what do do about water getting in there. any ideas? how do shaker hoods do this?
RE: make that hood scoop functional
ORIGINAL: domesticlover
[IMG]local://upfiles/20167/F8361C892E064E1B8C0DA399D4CDB74E.jpg[/IMG]
Edit: I know this is the CDC scoop, but the factory mach scoop works pretty much the exact same way.
alright so when i make this itll go straight across the bottom of the hood weather stripping with seal as good as it can but if i throw in some holes in the passage it should let most of the water out? is that what u guys are tellin me?
Not nescicarily in the passage, but in the bottom of the air box (find the lowest point cuz thats were the majority of the water is gonna go). Or you could put a dip in the passage and then put a small hole in it witha drain tube. so ya
If you put too many holes in your air passage to let the water out, you'll be sacrificing some of the ram air ability... Just put a dip in the passage way (it won't effect air flow too much) and put a weep hole in the bottom of the dip. The water will get trapped there and drip out.
