Final Suspension poll - hit it up.
all accessories included, bumpsteer.. x2balljoint.. c/c plates..
c/a's coming another day.
Please participate in this poll i want to see what everyone suggests.
"im a d/d but i want that edge suspension.. it completes the car. i want to be able to have attentive and responsive steering, and i want to be able to cut corners clean if i want at both high and low speeds. at the same time i want a good setup for drag 1/4's at the track "
RE: Final Suspension poll - hit it up.
Are you looking for a car that handles all around or for something that is really good in stright line performance? I have not voted yet, but will as soon as I know what kind of performance you are going for.
both. ive gone over this. but here..
You kind of have to decide which is more important straight line or cornering. Higher your spring rate the better you are going to be able to corner but the worse your weight transfer will be. As far as shocks and struts sounds like you should go for some sort of adjustables. I've got the Tokico Illumina 5 way adjustables and I like them. I would pick none of your options above. Get some LCA's, SFC's, and springs of your choice (I prefer H&R) should cost you about the same as your options above and your car will alot better in a straight line and around the corners.
so:
EIBACHS = soft (rate) spring
H&R = hard (rate) spring
well.. i want a nice low tight drop.. i dont like the wheelwell 4x4 bs junk and the 1.5" drops are not that low.
what would you suggest i do? sportline is like the perfect drop.. the supersport h&rs arent that low..
I like my car lower than stock, but my primary goal is to get the lateral G's up as high as I can.
Too much lowering messes with the front suspension and steering geometry.
The H&Rs drop a coupe 1.25" in the front and a convertible 1.5".
I also have Steeda balljoints and bump steer kit coming.
You can use the Steeda balljoints to drop the car another half inch if you leave out the spring spacers.
but than the car would be to low.
so you guys are pretty much sayin with eibach sportlines, and adj tokico dspecs im going to have a worst rate of acceleration, etc..
