Compression Problem...
Old Apr 10, 2006 | 02:38 AM
monkeydude3's Avatar
monkeydude3
Default RE: Compression Problem...
and to my knowledge you could not do a PI swap on one side... the PI heads require the PI intake manifold so it wouldn't all coordinate...
Old Apr 10, 2006 | 09:28 AM
4.698GT's Avatar
4.698GT
Could be the valve seats, could be the rings, could be a number of things. I can only remember those two at the moment.
Old Apr 10, 2006 | 10:42 AM
VARifleman's Avatar
VARifleman
Your drivers side seems to be at the compression that is normal to a PI swap (~10.5, 10.2 in this case), your passenger side is 12.25:1, although I have no idea why it would be that way.
Old Apr 10, 2006 | 11:46 AM
rbstang's Avatar
rbstang
now that my ADD drugs have worn off. it sounds like the seals on the pistons are leaking or the piston rings are busted. does it make noise or run like crap?
Old Apr 10, 2006 | 02:28 PM
kecclest's Avatar
kecclest
I have the PI intake manifold... I've read that you can put the PI intake on without doing the PI headswap.
Old Apr 10, 2006 | 02:29 PM
kecclest's Avatar
kecclest
My car runs fine. It was bogging down in second when I powershifted from first, but I changed the spark plugs, and now that problem is gone. How can I check to make sure the timing is correct on one side or another?
Old Apr 10, 2006 | 02:31 PM
kecclest's Avatar
kecclest
My car runs fine. I don't see how all the passenger side rings could have gone bad at the same time and with such precision.
Old Apr 10, 2006 | 03:07 PM
2VNA's Avatar
2VNA
the tool you used? was it new or a rental? That could be the problem right there. I like to look at the cheep way's first before tearing things appart. What plugs did you put copper?
Old Apr 10, 2006 | 03:11 PM
kecclest's Avatar
kecclest
It was a rental from AutoZone, but i was the first to use it (I saw him taking the plastic off of the box). The entire driver side read about 180, and the entire passenger side read 150. I put Bosch Platinums on it because I didn't want to put the old nasty looking ones back on.
baddog671
Jul 26, 2016 01:20 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
bconboy
Sep 21, 2015 12:52 PM
uberstang1
Sep 20, 2015 06:42 PM
1st 4 eyed fox
Aug 24, 2015 06:56 PM
