Mach 1 Grill Delete 2pc vrs 3pc?
Whats the main difference between a 2pc and 3pc mach1 grill delete? Trying to find a reason to justify spending twice as much money for something that looks exactly the same...
RE: Mach 1 Grill Delete 2pc vrs 3pc?
i think the 3 piece is the oem equipment on the mach 1? the 2 piece is an aftermarket kit, not oem. i think the 3 piece looks a lot cleaner from the ones i have seen.
Check out the install procedure at www.fordmuscle.com/archives/2004/07/Project01GT/ They show a pic of the 3 piece.
If you look at picture number 10 there, you'll see the middle has a square hole in it, while the stock gt one doesn't have that. I'm sure you could probably cut one into it though.
Its cool, my best firend is a tech. at Ford...I just told him to order me the chinspoiler, grill delete, and 02-04 headlights tomorrow. He gets anice discount.
2 piece rocks ! less weight then the 3 piece ! haha you save an extra .00001 lbs.
2 piece is the bottom piece + pony
3 piece is the bottom piece + some piece that go behind that bottom piece and the pony.
