Vortech Supercharger?
#21
RE: Vortech Supercharger?
ORIGINAL: SOHCtimes2
Lol they are both S-trim...the difference is V1 or V2 SQ but both are S-trim (same size). And if you want to hear the "whistle" really loud get a V1.
ORIGINAL: 97stanger
So basically, if you want to hear the whine get an S trim??
#22
For everybody that went with the Mongoose Kit from MPH...did you get a dyno tune after you installed the SCT tune done by Tim or was just installing the chip good enough??
Here is everything i came up with so far that I would need to make the comlpete install...let me know how it looks
Mongoose S-Trim kit
Stock Pulleys
Clock gauge pod with a/f and boost gauges
Thats all that i can think of to make the complete install...
Mongoose S-Trim kit
Stock Pulleys
#23
ORIGINAL: 97stanger
Mongoose S-Trim kit
Stock Pulleys
Mongoose S-Trim kit
Stock Pulleys
#25
You use Tim's tune, but you are supposed to get a dyno and have your AF ratios checked and everything. Then if there is anything wrong with your AF ratios you can send Tim the graph and he will tweak the tune and mail it back or something. Not sure exactly how it works, but I do know you are supposed to get a dyno to have your AF ratios checked after the install.
ORIGINAL: 97stanger
Mongoose S-Trim kit
Stock Pulleys
Mongoose S-Trim kit
Stock Pulleys
You can tune the fuel curves yourself if you need to tweak the tune after you get it on the dyno. I don't think your gonna have to, Tim told me the dyno run is mostly to check the install and make sure you don't have a bum fuel pump or injector.
97, you really should go with the SQ trim blower. It won't be loud, but none of the centrifugal blowers are going to have the 03 cobra sound anyway. Tim has proven it makes more horsepower with equal setups.
If I were you I would get it setup for a 8 pound pully and then install the MPH powerpipe while doing the install. That should get you to between 9 and 10 PSI. I would not go past 10 PSI on a stock shortblock.
BTW, why would anymore boost "wear the wrist pins"??? The real problem with more boost is the possibity of detonation, and simply that you make to much RWHP on the stock shortblock. Gotta be careful with them ****ty stock pistons, or you will melt a hole in em with too much boost.
#27
ORIGINAL: 97stanger
does the mongoose kit with the s-trim already come with a 8lb pulley? Like, is the stock boost set on the s-trim 8lbs??
Get the SQ!
#29
ORIGINAL: 97stanger
well thats good to know i dont have to deal with all that pulley sh**...i only wanted to go with the S trim becuase i want to hear the whine...its music to my heart
The S is louder, but I don't think it is that much louder, and the stealth aspect of the SQ is oh so cool. I won't even put my "vortech supercharged" licence plate cover on cause I want to stay under the radar. Nobody expects anything from a late model GT, which makes it even better
