Installing some steeper gears need some help on the install...
Ok ive decided to my gear change my self. Ive got a pretty good idea on how to do it and i also orded the install kit. I would like to know from people that have done this before, what special tools and/or things i need to look out for or make sure i do when doing the gear removal and install. Thanks for the help.
-John.
P.s. If it matters i have a 98 cobra with a spool, 33 spline axles and currently have 4.10's in there right now.
-John.
RE: Installing some steeper gears need some help on the install...
man its going to be pain in the *** i never did it myself but i watched....you have to remove rear tires, rear brake calipers, housing, pull axles out, take a sledge hammer and knock the pinion gear out, after you get new ones in you have to use this little brush with this marker stuff to mark the gears then rotate the axles make sure your not healing or toeing the gears....should rub the marker off evenly not toward the tip or the back....have to shim the kit so that it doesnt
had a guy do mine , and he had a real bad time at it , also the abs sensors on mine have to come off soo you can get the axle out.they both broke in the process. Good luck
ORIGINAL: mustangman02232
what kind of gears are you installing and why, you dont like 4.10s?
heres my advice, take it to a shop and have it done right
Well the car has a spool, 33 splines and 410's and the best i could get with 28 x 15 x 10.5 is a 7.9xx in the 1/8. Im going to keep it all motor for now and instead of switching to a 26" tire ( wich i dont want to do bc of smaller wriknle wall) im going to put in some 4.56's. I ordered a 2 hr dvd of how to install ring and pinion. I also bought the install kit so im gonna give it a go. Tools arent a problem, i just wanna takle this bastard and prove my self that i can do it lol.
