Heads and Cams
Heads and Cams
Ok, well I would really like to get a SC but money is tight. I have talked with a speed shop that I have done business with in the past and they tell me that to work on the heads and to put after market cams in would be around three grand including labor. that's about $1000. - 1500. less than a SC. Well that sure is a lot of money too. and yeah, i have made some modifications w/my exhaust, intake and gears but i think if i could get about 300hp to the ground i would be happy. what do ya'll think? do ya'll think that the price they quoted me is about right?
Stever
Stever
RE: Heads and Cams
ORIGINAL: Stever
Stever
Stever
BTW, I would definatly not take 4.6 heads to a shop that has never done a port job on them before. Everything I have seen says it is easy to take out to much material and end up making less power instead of more.
RE: Heads and Cams
ORIGINAL: XxphantomsnypzxX
isnt 400RWHP pushing the stock motor WAY too hard?
MPH has a stock engine car (with supercharger cams) making 440 RWHP safely.
450 is right aorund the limit. I didn't want to make more than 425 just to keep it safe.
RE: Heads and Cams
o so you can make 450 to the wheels on a stock motor and its all good? I did not know that. Thanks.
RE: Heads and Cams
ORIGINAL: 06mustang88
i wouldn't say it's all good...every car is diferent. you could have the exact same setup on one car and it would be fine and the next car blow, but 400 rwhp is all good!
To the thread started you are definitely better off just saving up for the supercharger. IDK if this is an option for you but nitrous will get you to your mark real quick and alot cheaper and probably safer as well. To get to 300 rwhp N/A you are going to need basically every bolt-on including P&P heads and some nice cams, which is going to cost you quite a bit. Supercharger will be around $4K for the supercharger alone then if u want to run 400+ rwhp safely you will need a built bottom end. If you arent stupid with the nitrous you can easily hit that 300 rwhp mark and save yourself a ton of money.
RE: Heads and Cams
425 is right on the "safe" limit in my opinion.
RE: Heads and Cams
ORIGINAL: Sick96Stang
I agree every car is different, however I wouldn't say 400 rwhp is all good either u can very easily blow a motor with 400 rwhp.
If you have a good tune and run 93 you should have no problems with 400 RWHP. Bad tunes kill cars, not horsepower (up to a point anyway).
The tune is just the thing. So long as you have an experenced shop tune the car, you will be fine. Like I said, MPH has a car making 440 to the wheels with a stock shortblock, and a good tune.
RE: Heads and Cams
ORIGINAL: 2000GT4.6
You don't need a shortblock to make 400 RWHP reliably. I am making 425 safely on the stock bottom end. Several shops have cars in the 440 RWHP range.
