MIL elimintaors?
Old Apr 12, 2006 | 03:29 PM
MustangMan528's Avatar
MustangMan528
Default MIL elimintaors?
quick question, what exactly are MIL eliminators for and what exactly do they do????
Old Apr 12, 2006 | 03:32 PM
mself52's Avatar
mself52
Default RE: MIL elimintaors?
when you get an off road x or h pipe you no longer have catalytic converters which will make your O2 sensors throw a check engine light... mil eliminators replace those and give the car a false signal that everything with the cats is correct....
93BlackNotch's Avatar
93BlackNotch
They stop the computer from putting the car in "safety" mode.... The car will think something is wrong if you remove the cats because of the 4 O2 sensors... 2 before the cats, 2 after
Old Apr 12, 2006 | 05:48 PM
xx9gt6xx's Avatar
xx9gt6xx
So to sum it up, no check engine light, no limp mode =
Old Apr 12, 2006 | 05:50 PM
Dan04COBRA's Avatar
Dan04COBRA
Mil Eliminators (depending on the brand) Do either of two things: Work or Fail.
Steeda MIL's suck.
mustangGTdude1031's Avatar
mustangGTdude1031
It doesnt tript he CEL if you have a catted H pipe though, right? (aftermarket)
Old Apr 12, 2006 | 05:59 PM
mself52's Avatar
mself52
no it shouldnt.... just if you get LT's and a catted x or h youd need extentions so the wires would reach... but no LT's and catted x or h nothing needed
BCisme's Avatar
BCisme
if you have cats it won't trip the light. your best bet is not to do an o/r pipe unless you are going to tune it. the first thing your tuner should do is shut off the rear 02's.
Old Apr 12, 2006 | 06:27 PM
2VNA's Avatar
2VNA
no that's not correct. I have the Bassani 2 cat X pipe and had to put them on my two back O2's to get rid of the light.
Old Apr 12, 2006 | 06:44 PM
macdaddyslomo's Avatar
macdaddyslomo
anybody ever use the "spark plug non fouler" trick as an MIL eliminator ???
you buy a kit of 2 and drill out one with a half inch bit and screw it into the 02 bung, then the 02 sensor into it
pulls the 02 sensor out of the exhaust flow and lowers temp, causing it not to throw a CEL
