Can I use Synthetic Oil?
Hey,
I was told a while back that unless you go with synthetic oil when the car is new, that you shouldn't later as it will sling it. So I forgot about it and just went with the Castrol 5-30. After reading on here, I wondered if that was really true. If not, what is a preferred brands to stick with? Would this be a situation where a blend is preferrable?
Thanks much for the help!
-I
-I
RE: Can I use Synthetic Oil?
Every used vehicle that i have had, i went with synthetic oil. Mileage has ranged anywhere from 20'000 to 60'000 miles and i havent had anytrouble at all. Mobile One is what i like.
ORIGINAL: 03GT96
but the question at hand, that I also would like to know, can you go from regular to synthetic after many miles? Or should you stay with regular?
I'm goin valvoline max life regular soon (I think it's a blend)
I've always thought oil is oil, you just have different quality levels
ORIGINAL: Smooth_J
Not to hi-jack the thread, but how often do you change the oil since you use synthetic now?
ORIGINAL: 03GT96
